geem
Yep, mine are bolted through with numerous M10 bolts through substantial bulkheads. We pulled a couple of bolts on the chainplates and the bolts were,perfect. Let's hope they were typical of the restSame with my even older Golden Hind. However unlike many designs (such as the tri in this thread) all the chain plates are external bolted through the topsides with stainless backing plates inside rather than passing through the deck. A disaster waiting to happen unless the seal through the deck is perfect and the attachment below is not hidden or embedded in a knee or a bulkhead. Many 1970-1990s designed boats fail in this respect - and the chain plates fail through a combination of crevice corrosion and stress, just as in the photo in post#34.
Probably little to do with the quality of the material - even the best 316 is susceptible to crevice corrosion.
Design of shroud attachment has come a long way since then with first through deck tiebars down to the keel through such things as internal structural bulkheads or dedicated webs to the keel load bearing structure or more recently back to external chainplates bolted through to laminated internal structures and even composite laminated into the hull structure.
