sarabande
Some pretty detailed discussion with an experienced sailing friend has recently explored some possible answers - all with advantages and possible disadvantages.
Scenario
Boat A needs a tow in rough conditions, and needs to join two purpose-made lines together to pass to towing boat B.
One suggestion is that both ends of the lines should be prepared with small soft eyes, and then be joined with a Swiftlink.
Another is to join the lines at the prepared eyes with dyneema wraps and anti-chafe.
And a third is to use a hard eye at one end of each tow rope and then use a decent shackle like a tested lifting Crosby in each hard eye to join the warps.
I have reservations about using knots to join tow lines, as the forces are likely to be in the order of several KNewtons, and chafe is a strong possibility, as is the load jamming the knot - unless someone knows of a rope-to-rope knot that will definitely undo after really heavy loads ?
Does anyone have any idea what sort of forces are involved in towing , say, a 6 tonne boat in rough weather ? 20 to 30 KNewtons (2 to 3 tonnes force) ?
How best to join the bits of cordage ?
Scenario
