Uricanejack
Re: Joining long two lines - how to do it ?
Yes, trouble with the carrick or the even better diamond carrick. Time and having something to seize the tails otherwise a double sheet bend is quicker and easier.
If I have time a short splice or double eye splice.
Reality check. Unless I am towing a tender. When would I ever tow with a sail boat. I will just sort out what I have and do the best I can probably a couple of spinnaker sheet joined by a sheet bend.
I would use a carrick bend, which according to Ashley is one of the strongest bends available, and is specifically recommended for joining anchor warps. It is also very easy to undo while remaining secure. There are two ways of using it; one is to tie the knot and leave the ends free; on taking a tension the knot will collapse into it's stable form with a long bight at each end of the knot; pushing those sideways will open the knot. The other is to seize the ends to the standing parts so it remains in the under-over pattern used to tie it ; this is what Ashley recommends for anchor warps. If in a hurry I would use the former; both are very secure and very strong.
If there is time to prepare I would suggest a spliced eye in each rope and then thread them through each other, reef knot style. That CANNOT come undone, short of the splice failing, and should remain reasonably easy to undo.
The majority of classic knots will remain easy to undo after being under load - it was part of the selection processs that made them classic knots! However, in come cases you do have to know how they come undone easily.
Incidentally, the bowline and sheet bend are structurally the same knot, so there is little advantage in linking two bowlines. The double sheet bend is no stronger than the single one, but is less likely to slip with modern materials.
