henryf
Speaking with Roy (Spotty Dog) last year at one of our Beer & Natter sessions he mentioned that he’d bought into a company which produced straps and webbing for various applications. Long story short they had some good products but needed a bit of help in terms of direction so he got involved.
One of the products which interested me was their range of dinghy / tender lifting straps which clip into the passarelle. When we changed the boat a couple of years ago we got a larger tender more suited to chartering where a little more capacity was required. I cobbled together some straps using what was available in the Swanwick Chandlery, it has worked, nobody has died but after a couple of seasons it all looks a bit scruffy and in the back of my mind was always the question of what if something snapped and I had to repair the bathing platform or worse. We have a relatively light tender / engine set up but even so….
I won’t lie, when we chatted through the options and Roy sent me to his website www.rapidmarine.co.uk I struggled a bit with the price. Some stuff in life you can justify spending money on, other stuff you have it in your mind should be cheap. I don’t know what my Heath Robinson straps cost, probably 50 quid or so, a big difference to Rapid Marine's kit. Roy explained that many of the components had to be specially made in order to conform to the load test requirements and that added considerably to the cost. Each strap comes with a certificate to confirm it’s maximum rating etc. so in the event of a disaster there is no danger of the insurance company blaming you for using cheap string
This weekend I finally bit the bullet and the old adage of pain of price being quickly replaced by appreciation of quality was immediate. Something as simple as some straps had been really well designed. Adjusting everything to fit the tender was easy although I still can’t quite see how it gets longer or shorter, there are no loose ends !
I also got a couple of tie down straps, one of which in provides a particularly neat solution to a problem we had using the standard mounting points. Everything came in very smart wash through net bags which makes rinsing off easy.
No connection with the company other than knowing Roy through the forum but as a very happy customer I wanted to openly thank him for his advice and ultimately the product.
edited to say I haven't actually got an overall shot showing the tender supported from the passerelle, I will sort one out at some stage.
Henry
Henry
