BruceK
Can anyone point me in the direction of what to look for first to remedy the problem. I've posed the question to a number of mechanics as to why the port engine uses more fuel and the response has always been there's always a lead engine. But 30% is a bit of a big ask imo.
Aging 34 foot cruiser running twin KAMD42's. She's an old boat, nothing is perfect, but we try getting there
Each engine has an independant fuel tank with no balancer between tanks.
Each refill I can expect to put roughly 30% more fuel into PORT tank.
further information:
propellors recently changed so not props. DP290 duo props
Tacho's probably not that reliably accurate but I balance engines to harmonics as much as possible.
I carry about 150kg of ballast on port side. This was put in firstly as the boat always had a list to starboard of about 3 degrees. I initially attributed this to removed equipment such as inboard genny, AC, vacuum and icebox that used to be located on the port side. However I'm not so sure the list was not created by the imbalance in fuel tanks. (I used to put in equal quantities per tank, i.e. 250 litres each side)(Each tank is ~400l)
underway at cruise, port side trim is often activated slightly more than starboard
Possible toe-in alignment issue between drives. To check on season lift
Starboard engine carries domestic calorifier
Starboard engine trim sensor not very well callibrated (i.e. possible small difference in trim angles)
Starboard engine does tend to run cooler on average according to guage Sub 80C whereas the port is 80C
No hull obstructions
Engines were completely rebuilt 4 years ago including new injectors etc. The engines when underway have always received favourable comments from those in the know for how good they sound for what it's worth. i.e. visually and audibly they sound very healthy.
Turbos both kick in at same times (no boost pressure guages to verify balance though) and harmonics dont change as throttle is applied so I'm assuming they're in the same boost range.
