Sumara of Weymouth
Always a bit hard to say when it's not your boat but I think I would do the following:
a) Rig a slip line travelling from a cleat or a winch near the helming position starboard aft going to a position on the gangway walkway mid-way between the two boats. The line will need to be as long as your boat plus the length of the boat alongside (doubled plus a bit). Use polypropylene so it floats and wont foul the prop. If you are worried about slipping a line so long, perhaps use a single polyester line with sinkers but that assumes you are returning to the same berth.
b) Undo all the other mooring lines.
c) Assuming there are two crew, have the crew walk the boat slowly down the pontoon, holding it close to, while the skipper has the helm held hard to starboard (to counter your propwash) and the engine in very slow reverse.
d) When the boat reaches near the end of the pontoon the crew gets on board. An agile crew might be able to do some jumping and assisting to swing the boat, but let's avoid that.
e) Apply a bit more reverse speed while letting the slip line gradually slide out.
f) Once the prow of the boat is well clear of the pontoon stop the rope from sliding anymore and motor moderately hard astern against the restraining line.
g) The prow should pivot and swing through the wind.
h) Once the prow is through the wind, haul in the slip line (or drop the sinking one) engage forward gear and gracefully sail away.
i) At all times keep that smile on your face, even if it all goes wrong. Most people will assume you meant to do whatever your long-keeler has decided to do and don't blame me if it all goes haywire.
