Wansworth
Looking at a Puma 32 which apparently has a sandwich deck and reports indicate there could be delamination in the type of deck,any pointers,thanks
Yes,thanks……saw this Puma32 in Ferrol and checked up on a Spanish forum ….yes the class can have deckproblems..so no rush to visit FerrolI'd add to Fr. Hackett's advice listen out for creaking as you walk around the deck, coachroof, etc..
Zillions of boats have laminated decks. Most of them are fine. Quite a few have minor delamination that you can live with. A few have extensive delamination, and are (for your purposes) best passed over and look for something else - repair is simple in principle, but very messy and time consuming in practice.
The main issue to avoid, as far as I'm aware, is not so much simple delamination, but boats with balsa cores to the laminate, where water ingress (usually the result of improper methods of 'through-deck' bolts/fittings) has resulted in the balsa rotting, leaving two layers of GRP with little between them.
My advice would be to make an offer that feels stupidly below the asking price, as the seller may well accept it. If you can get the right price, then you can afford a professional repair.
Thanks,good infoWhen we bought our boat last year, the broker told us before we viewed it that the roof was soft, due to the balsa core getting wet and rotting away. The area affected was between the hatch garage and the mast base (thankfully the actual mast base is sound and unaffected). Because of that, we got the boat at a very reduced price, and we have booked in a repair this autumn - the boat is fully safe for us to sail on this summer while we wait for the repair date. We considered options for cutting through the upper layer of GRP (the surface that you stand on) or the lower layer (hidden above the ceiling boards) and have settled on the upper layer since that makes the repair easier to do. Our guy is going to cut away a large section, fill with new structural foam core, then re-lay the upper layer and bond it to the remaining original. When he cut into the top surface to inspect the core, it was very soggy indeed. I will update again on the work when it is in progress, for the edification of anyone interested.
Wise words…….oh that I could live with a spongy deckThat might suit some, but my advice to Wansworth in particular is to avoid a boat needing such significant work. (They all need some work.) He's put off going sailing again too long as it is and, comfortable as his sofa may be, it puts him in the way of Mrs. W. tasking him with domestic DIY. He has 'projects' enough to be getting on with. He needs to get out and on the water. Nice as it may be to have a valance to hide the pipework under the sink, or be responsible for giving a boat with some significant defect a new lease of life, it's not life enhancing in the way that wafting about a ria, or just sitting in the cockpit watching the world go by, can be. That doesn't require the perfect boat, but I'd suggest it is most likely to be achieved by a boat that's more or less up together.
I feel I can speak with some authority, as one who's own boat is ashore demanding significant boat maintenance drudgery, rather than skipping over the waves in the sunshine.
