seeSimon
6 x 6 fence posts, or railway sleepers are good, and can be readily cut to useful length with a chainsaw. Not too heavy, unless waterlogged. Not too expensive, compared to "boat props"...
Alternatively, you could tell everyone you’ve filled it in and lightly cover it over with brushwood.If your boat is sat on mud, grass, etc. then you could dig a slot in the ground about 2'6" deep; enough to lower the keel into.
Make sure you fill it in afterwards...
Likely a bad thing if weight of the boat is on the swing keel. It may have rollers or bunks which can be raised to take load on hull. need to lift hull to adjust or modify.Glad to know wood is the way to go, makes sense instead of the props.
Our boats in the garden and not sure how keen the adults are on digging a hole…tho I did think about that already.
The trailer doesn’t have a slot for the keel and pretty sure not a continuation for winching on and off either but I need to check next time Im at the boat (it’s actually in my friends garden). I do know it’s not the trailer meant for our boat
That’s certainly something to bear in mind, but this isn’t a big boat. Very likely she’ll be fine as lomg as the trailer gives her some support, is adjusted to fit the boat. That kind of problem increased exponentially with the size of the boat.Likely a bad thing if weight of the boat is on the swing keel. It may have rollers or bunks which can be raised to take load on hull. need to lift hull to adjust or modify.
I would not want to use it on the roads with weight on the keel. ol'will
Yup I think we might all have been over-thinking this a bit.A lot of these ideas like digging holes and jacking boats up off trailers are quite a signifcant effort. Anything can be done if it needs to be, but it seems to me it would be far easier just to launch the boat and see how it works. I know you said you had a concern that it might drop off, but even if the very worst happens like that, as long as you've done it somewhere where the keel could be recovered at low water (like on a slipway), you can sort things out. And if you've visually inspected the whole lot beforehand I'd say its more likely you'll be hit by a lightening bolt doing the job than it falling off. If it jams, you can figure out why.
Alternatively (or in addition), can you remove and check the conditon of the hinge pin with the keel still up and on the trailer? That's what supports the weight of the keel so as long as the hinge is in good shape and everything else looks fine through the inspection hatch, I'd say the boat was good to go. If it were mine, I'd probably just look everything over now, wait a few months until Spring, launch it and try it first time around in the water carefully/tentatively. Maybe I'm too lazy for digging holes - although I've dug plenty in my time it isn't my favourite pastime ;-). Or it is fun with a JCB, but that's a different story.
What does the metal look like underneath the paint? If it's galvanised then you might be ok for a while. Ideally you'd remove the keel completely, take off all the existing paint, and then prime and antifoul. But I wouldn't worry about it too much in the short term.Thanks, your right I reckon we can just leave it for now, maybe check the keel pin, and just launch her and see how that goes. I was wondering though if the keel needs a repaint as it’s flaking quite a bit or is that not an issue for something metal that’s underwater anyway?
I’d put Seachanges idea on your list for sure. But this boat being new to you, you’ve got a long list I daresay. You need perhaos to decide what stops you going sailing and what does not. Having a lovely smooth freshly painted keel is going to make you sail faster and better. Not stop you. If you’ve got the time and money, go for it.Thanks, your right I reckon we can just leave it for now, maybe check the keel pin, and just launch her and see how that goes. I was wondering though if the keel needs a repaint as it’s flaking quite a bit or is that not an issue for something metal that’s underwater anyway?
Yes agreed . However jolting on a road would be much more severe than sitting on the bottom with probably some of the weight taken by the chines.OK .. agree ... but don't forget that such boats also sit on the bottom dried out in tidal waters ... if the keel cannot do that - then somethings wrong.
Be careful using a telehandler - the forks are usually quite close together which can make the boat unstable when lifting. Ideally you need a rectangular frame which fits the forks but is longer and wider, with attachment points for the slings. It also prevents the slings from crushing the sides of the boat.If this is in you own yard, then a local farmer will lift it easily with telehandler for beer. Support on good sleepers. Dont mess about hand lifting, you’ll kill yourself!
Agree.That’s certainly something to bear in mind, but this isn’t a big boat. Very likely she’ll be fine as lomg as the trailer gives her some support, is adjusted to fit the boat. That kind of problem increased exponentially with the size of the boat.
I might think about wrapping it with a ratchet strap if, on inspection, this was a concern.Agree.
However , imho, you really don't want to road tow the boat with the weight of the swing keel sole supported by the boats lifting mechanism.
Similar issues with an outboard dangling off the transom.
