Plum
+1Put like that it’s a difficult question to answer, but I, for one, appreciate that you do.
Plenty of smoky yacht engines out there.
Premature bore wear?
Plenty of yacht engines getting replaced at low hours compared to generators on shore.
Perhaps ideally you'd 'winterise' the engine. particularly removing the exhaust, so that damp is not rising from the water lock and condensing on the valves and any cylinder where the exhaust valve is open. That used to be the traditional advice and it's what I do.
Second best might be to spin it over decompressed to re-oil the cylinder walls every week or so.
As I said, I've never had a Perkins, it's general advice which doesn't help in this case.Interested - where's the decompression lever on a 4 series Perkins ? My 4-107 hasn't one ... my 4-99 never had one ... workshop manual for the 4 series incl 4-108 doesn't show one ...
Slight drift my Mercury Two stroke was slightly seized after not being used for nine months. Some
oil down the bore and a spanner instead of the pull cord and I turned it over with slight force. It
started and ran OK afterwards. I used to visit my boat once a week and always turned the engine
over a few times using a spanner on the nut holding on the crankshaft pulley which is at the saloon
end on my boat.
end on my boat.
But there’s only one true sourdough recipe - every sourdough book tells you that and every true way is different.Winterising engines is a bit like baking bread.
There are those who treat it like a black art, using all sorts of arcane methods and ingredients, with copious warnings for tose who don't treat it with the gravity it deserves, then there are those who grab whatever's at hand and bake it in (or on) whatever they've got with more than satisfactory results.
Like many I cannot get to my boat either to use it, or just run the engine up. Assuming that lock down is going to go on, how long is it safe to leave the engine/boat unattended; the engine is a c1980 Perkins 4108 and the boat a similar vintage yacht. I have had an offer from a mechanic who is prepared to run the engine up, wash the boat and check it over, for which he is asking £300 for 6 visits. Now that goes against my thinking, but am I likely to end up with a bigger bill if I just leave it to sit?
Any thoughts?
What sort of imbecile marine engineer would tell his customers they needed to pay him to "change the oil and the filter (using preservative oil, if you can get it) turn the engine over after introducing some oil into the cylinders, spray the exterior with some anti-corrosion oil, "
That's easy. Plenty of rogues in every trade who con unsuspecting customers in parting with hard earned cash.
My car gets left for 6-7 months at a stretch, only things I do to it are disconnect the battery and blow the tyres up to 40 psi. Boat gets left once a year for 3 months or so, no need to winterise as no freezing conditions, I just isolate the batteries, turn solar charge voltage down, turn gas off and close sea cocks. Can't understand why people worry so much.
I would get him to flush through the cooling system and either drain it or put some corrosion-inhibitor in it, change the oil and the filter (using preservative oil, if you can get it) turn the engine over after introducing some oil into the cylinders, spray the exterior with some anti-corrosion oil, cover the engine and then leave it alone. Also disconnect the battery and fetch it home so you can keep it charged.
Why on Earth would you do any of that ?
The OPs engine is fresh water cooled, so already full of corrosion inhibitor (in the anti-freeze). The rest is simply pointless too.
.Times do change, as do materials and we learn new practices. With our modern diesels and modern oils, there honestly isn't any need for all of the measures that were needed in 1935. But, don't let me stop you doing them if you're bored ?
I think in most cases the wintering was carried out towards the end of 2019, following the procedure you have linked to. The question as I understand it is what should be done now while the boat cannot be used. I see no reason to do anything at all until we can get back to our boats, whenever that may be..
Below is a link to Owner’s Manual for the BUKH DV36ME marine diesel engine in which is set out the winterising procedure. I offer it as one example. As far as I know, these engines are still in production and they are designed to have a very long service life.
I cannot see anything in there that does not seem like a reasonable precaution to take to protect what is probably the single most expensive single piece of equipment found in the typical cruising yacht.
So, leaving aside our obvious mutual dislike, when it comes to long-term storage of an engine I can see no reason why I should follow your advice and disregard the recommendations of an engine’s manufacturer.
But perhaps you can answer two questions for me:
1. Why would an engine manufacture recommend maintenance work that was not necessary?
2. What justification has an owner have for not doing as the manufacturer recommends, if he can? Especially when, as now, there is no way that he can possibly know how long it will be before he is able to use his boat again
These boats that people are worrying about, what are they so far, 2 weeks overdue from their normal launch and use window ?
