Engine Problems.....
Zepph
New Member
2 Jan 2026
Boat type: Sigma 33
Engine: Volvo Penta 2002 (we believe)
We have recently purchased a Sigma 33 (fantastic to sail, apart from dead downwind), the engine was running smoothly for a week.
We then didn't use the boat for a week and when we came to start it nothing, engine seems to turn over fine batteries look okay however she doesn't start.
We presumed that we had run the engine dry, we filled it up with about 15L at which point no more fuel was going in.
We tried to start her again, no success at which point we had to call it a day.
Came back a week later, and went to check the fuel system fuel looked to have come out of the breather pipe which leads up to the deck.
We cleaned up the mess tightened the tubes and started again.
This is the point at which we decided to bleed the system, presuming air was the cause of our problems.
When we opened the bleed screw fuel came out of its own accord, we didn't touch the lift pump. I let the fuel run out for a minute or so before closing it off.
Could we have over pressurised the system somehow?
We haven't bled the injectors yet, however if fuel shouldn't be coming out of the bleed screw on top of the engine without turning the engine or pumping the lift pump i would like to address this first.
Boat type: Sigma 33
I once had a Volvo MD7 with worn piston rings. It wouldn’t start after not being used for a week or so (oil drained down the cylinders past the rings? I’m NOT a mechanic!) but in regular use, it would start fine. To get me to the end of the season and a re-build, I drained a little oil (still well above ‘Min’ on the dipstick) so that I could add a little oil from the top which seemed to work by sealing the rings and increasing the compression. Worth a try?
There could be several reasons for non starting, but I have a possible explanation for the apparent fuel anomaly. You filled the tank until it was absolutely full. Possibly the temperature rose, the fuel expanded, causing it to come out the breather pipe onto the deck. That meant that the fuel level was well above the level of the bleed screw, which explains why it flowed out. No, you haven't over pressurised anything. As others have said, don't keep on cranking the engine without shutting off the inlet sea cock. There is a danger that you can pump so much water that it fills the exhaust system, and floods into the engine.
If you did run out of fuel, based on personal experience with my VP2002, air will get into the line above the filter and you will need to bleed the injectors to get it restarted.
my engine is a pig to bleed until I learnt to crack off two out of the four injector fuel lines. That should allow any air to be purged and the engine sound like it wants to start. Once it sounds encouraging tighten them back up again and try starting again. Works best if you can have one person on the key and another by the fuel lines to check diesel is spurting out.
Sounds like you are not following the start instructions properly. You need to pull out the stop lever to set the the fuel pump to deliver a ricj mixture to start. Once the engine fires the enrichment leever returns to its "run" position automatically. They are poor starters when it is cold so need a lot of cranking. As suggested turn the water off while cranking if it does not start straight away. Before trying again you need to go through the same procedure. When it runs turn the water back on.
Google Volvo 2002 start procedure for plenty of advice including youtubes explaining it all.
