Gennaker mast head U bolt size
Travelling Westerly
20 Dec 2019
Dorset
I was re fitting my gennaker halyard mast head pully today and experienced a slight challenge whist up there.
The 2 holes drilled in the mast head sheave box plate cover were spaced apart by 24mm. The only U bolt I could find at 24mm spacing was a 6mm arrangement which has a WLL of 656kg. I'm not sure if this has enough strength to take the power of the gennaker when in use.
The old arrangement was an 8mm affair but it got lost when it was removed a few seasons ago.
The gennaker is for a 12m, 12t (ish) cruiser and has a 17m luff. Im not sure how to work out its size though.
I'm worried that the 6mm thick U bolt won't be strong enough up there..
Does anybody have any thoughts if it's suitable or not?
Frogmogman
26 Aug 2012
The formulae I have for sheet and halyard loads (for a Genoa, not a gennaker) are
Genoa sheet load in lbs = SA * V² * 0.00431.
Halyard load in lbs = (SA * .00256 * V²) + Sheet load
SA = Sail area in sqft
V = Wind speed in knots
justanothersailboat
2 Aug 2021
Selden, or before that Kemp, masts sometimes (often?) have a U-bolt that is not a standard U-bolt size - it's narrow for its thread diameter, like you describe. So you're kind of stuck with the expensive Selden one I fear. At least that's what happened to me!
Travelling Westerly
20 Dec 2019
Dorset
Ah fantastic help, thanks team, much appreciated.
I do indeed have a Selden/Kemp mast. I had no idea it could be a Selden U bolt.
I wondered about the strange size and why it was slightly bent when I removed it!
I wish I hadn't put it in such a secure place so as I cant find it again.
Thanks again
Martin_J
19 Apr 2006
Portsmouth, UK
I'm not on board at the moment to check my spare... but I really seem to think that it's the larger one of those Selden ones used at the masthead on my S38 .
Double check... Allspars or other Selden agent will know for sure.
