Gearbox oil
Neil
6 Apr 2004
Ireland
When I bought the boat in 2012, it had just been fitted with a new Beta14, gearbox, exhaust and fuel tank. The engine service page noted that the gearbox oil had been changed at 25hr and there is no other checkbox for gearbox oil. I just came across the manual for the gearbox, which asks for the oil to be changed every year. Does anybody do that? Can't remember when I last changed the gear oil on my car, actually never?
doug748
1 Oct 2002
UK. South West.
I change the gearbox oil every three years on my 20hp job. Technodrive gearbox, ATF oil.
The maintenance schedule, section 2 in the Operators Manual, actually specifies every 750 hours.
nathanglasgow
23 Jul 2008
Oil is cheap,gearboxes are expensive.We change the engine oil and gearbox oil in our wee Beta 13.5hp every year.Gearbox takes less than a third of a litre of AFT.Simple to do,just suck it out with length of tubing and a big syringe or outboard type fuel line pump.
cryan
5 May 2013
Kirkcaldy, Fife
www.cryco.co.uk
Check the correct oil to use. ATF might be to thin for some gearboxes. All oil majors will produce the correct grade of oil specifically for gearboxes. I tend to use Shell because I'm familiar with their range but castrol, mobil , texaco etc all do the same.
scottie
14 Nov 2001
scotland
You only change it to inspect the oil for traces of water or other contamination such as swarf from burnt or slipping plates etc the oil itself will not deteriorate over 12 months or a lot longer
Discolouration is one of the first signs of problems.
Neil
6 Apr 2004
Ireland
What's AFT? The gearbox manual doesn't seem to specify a specific lubricant, not that I could see anyway - I'll have another careful read.
RAI
13 Jun 2006
Ayamonte
ATF - Automatic Transmission Fluid, I believe. You do need to get the right oil. Some gearboxes run on engine type oil.
Tranona
10 Nov 2007
Pretty sure you have a TMC gearbox and the operator's manual very clearly states ATF - in fact every little drawing related to oil has a little oil can graphic with ATF alongside it. Oil change after first 30 hours then every 500 hours.
Hydrozoan
11 Apr 2013
+1 I usually use the drain plug but it's a bit of a nuisance to get a plastic tray under it, so I'll try your syringe approach next time as the volume is indeed so small - thanks. One point with our gearbox is to remember to use the dipstick without threading it in, otherwise you'd underfill significantly.
PuffTheMagicDragon
When you contact the manufacturer have the serial number of the gearbox handy because sometimes they change from ATF to engine oil (or vice versa) for the same model of box.
Neil
6 Apr 2004
Ireland
Its a TwinDisc Technodrive (TMC 40P:maybe?) and the manual has a pictogram of an oilcan with ATF inscribed inside......Doh!
LittleSister
12 Nov 2007
robertg1
2 May 2009
I came across this thread because I was looking for which specification of ATF to use in my TMC40P gearbox and could not find the answer. Just telephoned Beta and they told me to use Dexron II or Dexron III.
