Swampyhotdog
Hi There,
I bought a Jeanneau 36 in Turkey, and on my way to Mallorca the engine overheated. I removed the thermostat, and on doing so I discovered that the housing is full of dried on salt deposits (The engine is direct seawater cooled).
I'm assuming that the whole engine is full of the same, and it's only a matter of time before the cooling spaces are completely blocked.
In the merchant navy we use SAF acid to clean stuff like this out of SW cooled compressors and the likes.
My question is should I clean the engine out with this, and go back to SW cooling, or should I fit a fresh water cooling system with heat exchanger etc
Is SW cooling a good long term idea, or does it just lead to problems in the future?
The other concern is that adding a FW cooling system just complicates things, with more things to go wrong.
What do you think?
Stuart
What do you think?
Stuart
