BabaYaga
The diesel tank on my boat never had a stop cock.
I believe it should have, so installing one is on my list of winter projects.
But I can’t quite decide where to put it and would need some advice.
The scene:
The tank is under the ”floorboards” in the sb cockpit locker, with the take off pipe on the tank top. From here, the rubber fuel hose passes through a longitudal bulkhead into the engine compartment.
It makes a small loop, which includes a squeeze bulb, before entering the head of the CAV primary filter (this is placed slightly over the level of the tank top, which explains how I have got by without a stop cock for so many years).
After the CAV filter the fuel hose goes down to the engine, with its lift pump, secondary filter, injection pump etc.
Do I install the stop cock:
1. By the tank, directly after the take off pipe (where it might be very difficult to access in a hurry).
2. In the fuel hose, just where it enters the engine bay.
3. At the intake to the CAV filter head.
4. At the outtake from the CAV filter head.
Any thoughts?
The scene:
Any thoughts?
