Fairline bulb replacement in cabin.
vas
21 Jun 2011
Volos-Athens
99% you carefully pull it down a bit, spot the two springy things that hold it up and carefully compress and remove. Sort of the system used on spotlights on plasterboards.
cheers
V.
Portofino
10 Apr 2011
Boat- Western Med
Voltage depends on the boat some 12vothers 24v found on generally bigger with 12L + engines ,beefier starter motors.
Now you know how to get them down think about refitting LEDs --see E -Bay .
Saves on power consumption and are cooler ,don,t get hot .Last longer too in theroey. Better all round .
5 W is a good starter if there are lots dotted around ?
