mick
I am replacing the above (the bit that receives the cooling water from the block) and would like to know if there is a gasket between this part and the manifold. I have three of the retaining nuts/studs off, but can't get at the one at bottom left (looking from gearbox end)to unscrew it. Any suggestions? I say nuts/studs because of the three bits I have removed, two came out as studs and in the other case the nut came away on its own. Is this normal?
