geem
Our induction hob is a single ring portable type. Bought about 15 years ago from Aldi. Cost £26. Still going strong.It's definitely possible to replace a gas cooker with an induction hob and electric oven, and it sounds like you have a good plan in mind for creating a custom SS frame to integrate these appliances into a gimbaled frame.
One lesson that some people have learned when making this switch is that it's important to carefully consider the power requirements of the induction hob and electric oven, and ensure that your generator and/or battery bank and inverter can handle the load. Induction hobs can draw a lot of power, and electric ovens can also be power-hungry, so it's important to make sure that your system is sized appropriately.
Another consideration is that induction hobs require a flat surface, and may not be as forgiving as gas when it comes to leveling the boat. You may need to make adjustments to ensure that the induction hob sits level and can function properly.
In terms of choosing the right induction hob and electric oven, it's important to look for models that are specifically designed for marine use, as these will be more durable and able to withstand the challenges of a marine environment. It's also important to choose appliances that fit well into your available space and can be easily installed.
Overall, with careful planning and consideration, it's definitely possible to switch from a gas cooker to an induction hob and electric oven on a boat. Good luck with your project!
I have metering installed. The induction hob pulls a maximum of 2kw when set to 2 kW. It doesn't stay at 2kw but pulses up and down so the average load is less. Since they use about 30 less power than a conventional electric cooker I would guess that they average about 30% less than the cooking Watts you select on the hob.
