rogerthebodger
If you have a large single block on the bridle line and the drogue attached to that both legs of the bridle will automatically have tension kept in then and also equalise the load on the chain plates better.
A recent JSD thread brought me back to this great discussion
Has our cumulative knowledge on JSDs moved on much over the last few years?
I have seen YouTubes where JSDs have chaffed through, where a JSD has destroyed a vane and where JSDs are a nightmare to retrieve
I have not seen, or read much about their effectiveness once deployed and I am not aware of any commentary on JSD chainplates that have actually seen use
Is there any new information out there?
I have plans for my chainplates.
As the poster of the other chainplate thread could I ask what your plans are for you chainplates?
Kind Regards
Really interesting to see your drogue in use and your thoughts anout it. Cheers for going to the efgort of sharingSure. Take a look at my site below. Use the second video. It shows the retrieval and some discussion about my chainplates and deployment bag at the end.
I have plans for my chainplates on the link below:
When I had to use the Jordan Series Drogue! | Chasing Contours
Helpful advice and you might just have saved me a lot of unneccesary trouble. I live in a place where westerly F7 to 8 are fairly regular (in Spain just N of Gibraltar) but the sea close inshore is deep, near tideless and fairly calm. I've managed to try my storm sail out in 30 to 35kn in these conditions and my JSD was next on the list. Your comment has made me realise how little it will relate to ocean storm conditions. I might as well rehearse deploying it under engine in calm conditions. I won't learn much more in strong winds but calm waters and hauling it back in would be a bastard - I already know that! And I'm not about to go out into the Gibraltar Strait to find the stronger winds and 3 to 4m waves and then drop a drogue over the side. The first thing I'd learn is how fast a wife's love can turn to hate ?Be careful how you view usage.
Being caught in 55 knot winds with breaking seas is slightly different, to entirely different, to simulating these conditions in 30 knots. What you can do at 30 knots becomes a heroic effort when the winds get up. Don't under estimate how bad and awful it can be.
If possible - don't get caught in 55 knots (or more) of wind
The ideal is, like a life raft, you never ever want to use a JSD, you never want to experience 55 knots (or more). None of it is very pleasant and bragging rights really don't count for much.
Jonathan
Or does anyone have a justification for 'several sections' and the attendent weakening knots/bends....? Or 'double braid nylon'. and 'tapered'....?
The theory as per Don J:
The overall forces that are generated by a Jordan Series Drogue are lower and the peak shock loading forces that the boat is subjected to is far lower by design. The design of the JSD allows it to gradually increase the resistance applied to the boat as the rode becomes more heavily loaded—and doesn’t have the issues with collapsing and suddenly re-deploying a parachute sea anchor does.
Experiences:
"First, the forces exerted on the boat by the drogue were truly impressive. The pull from the JSD, while gradual, would cause us to stagger if we were not holding on. "
"Further, as the boat is moving the rode is under constant tension so there is no shock loading even as waves strike the stern. "
Jordan Series Drogue experience - Cruisers & Sailing Forums
"We moved gently downwind at up to one and a half knots. As each crest passed under the yacht we accelerated gently forward until the drogue applied its force. Tailored to the displacement of my yacht, the drogue applied its force softly"
A Jordan Series Drogue can be a lifesaver – Yachting World
None of the forces alluded to are quantified in any way.
There are no shock loads.
Breaking loads for a threaded machine screw, as shown in your pic is: at the thread and in shear: 10mm - 2593 lbs; 12mm 4808lbs
A 30mm x 10mm Stainless strapping with a 10mm hole drilled through it would hold 12,656 lbs, 40mm x 10mm also with a 10mm hole would hold 20,246 lbs
Ergo, you would need a 40mm x 10mm chainplate held on by 8 10mm threaded machine screws to hold 9t.
GRP at chainplate attachment should be 1.3 times the hull thickness plus a distance of twenty times the smallest bolt diametre beyond the last bolt.
Dave Gerr, Boatstrength.
Hope this helps.
You need to consider the weakest part of the whole set-up. If the drogue is shackled to the chainplate, as one pic shows, the weakest part is probably the shackle pin - what's the shear strength of that?
... If loaded at 45 degrees, possible under the conditions being discussed, then the chain plates need to be considered for yield not their ultimate tensile strength. The UTS of the chain plates illustrated in Post 1 might be quite high - their yield strength will be much lower and its value more applicable. If the chain plate yield you are no longer simply considering bolt strength in shear.
Jonathan
