Drilling and tapping cast iron?
Thistle
2 Oct 2004
Here
I seem to remember doing this successfully with a hand drill (low speed!) and paraffin as a lubricant.
DaveS
25 Aug 2004
West Coast of Scotland
From my 1958 Higher Metalwork textbook...
Cast Iron:
No coolant is recommended for drilling, oil is recommended for tapping.
ISTR, but now cannot find confirmation, that the drill tip included angle should be reduced to about 100 deg, and that a low drilling speed and firm pressure were required.
Not sure about tapping, but seem to think that it will only work properly with fairly big holes / coarse threads (otherwise thread size gets too close to grain size).
nigelhudson
27 Mar 2005
UK South Coast
calculuscontracts.co.uk
It's not as consistent as steel - it can have inclusions and voids which can damage cutting tools. It's also abrasive and will wear tools faster than steel especially if you don't use a lubricant such as paraffin or a light oil.
The other difference to steel is that the swarf is powdery. When tapping make sure that you clear the tap every couple of threads - it's very easy to get it blocked with swarf and snap the tap in the workpiece (been there, done that!)
VicS
13 Jul 2002
Agreed. Drill dry but tap either dry or with soluble oil.
The standard drill point angle should be suitable.
VicS
13 Jul 2002
softer isn't it?
[/ QUOTE ] No, not according to the figures I've got.
Scleroscope hardness: Mild steel 18-25, cast iron 25-45
fluffc
31 Dec 2002
Southampton
It has a hard crust, which blunts drills quickly and needs quite a 'firm hand' to get through. Once you're through this, the 'core' is as others have described - feels softer but quite grainy swarf - clear out the drill / tap regularly.
FrankieJ
30 Oct 2006
Keswick - Cumbria
Cast iron is generally easy to machine, but if a casting has been 'chill cooled' it can be as hard as glass and virtually un-machinable. This is unlikely to be the case in normal applications.
Drill it dry and at a slow speed (to prevent over heating the cutting tool) and use HSS. drills & taps.Lubricant may be used for tapping ( Trefolex is good) and compessed air is good for cooling when drilling.
I have used clean water to keep the drill cool when drilling large holes ( like 2 1/2. inch dia.) but it rusts very quickly.
Final tip~~ keep cutting tools sharp.
~~~ A lifetime in machining~~~
cliff
15 Apr 2004
various
Cliff might come along and tell you. But there again.............. /forums/images/graemlins/wink.gif
[/ QUOTE ]Smart ass! Why does he need further advice - so far the advice offered seems reasonable to me however.....
I prefer to use straight flute carbide drills (not HSS) with lots of coolant for drilling, drill in a press drill - not by hand - to maintain medium pressure on the drill. Spiral taps, again carbide not HSS but as most folk will not have access to such tooling Ti coated HSS in a drill press, slow speed, lots of coolant or even compressed air (helps remove the waste and cool the bit at the same time) Keep running the bit out of the hole to cool and clean it, usual comments about pilot holes. For tapping HSS straight flute taps will do but use new ones that are shark and use planty of tapping fluid, backing the tap out every 1~2 turns. /forums/images/graemlins/grin.gif
"Artificial intelligence is no match for natural stupidity"
sailroom <span style="color:red">The place to auction your previously loved boatie bits</span>
jleaworthy
20 May 2002
Essex
Ashamed to admit this, but when I had trouble getting sufficient pressure to keep the drill cutting whilst drilling the cast iron of my twin keels (later tapped 10mm to fit anodes) I ended up using a masonry drill in my 5kg SDS hand drill set to hammer mode - and it worked. Didn't do the drill bit a lot of good, though.
Heckler
24 Feb 2003
its lovely to work with drilling and tapping, the carbon content keeps the tool steel happy and lubricated (simplistically)
