Diesel tank air vent
zoidberg
12 Nov 2016
I'm repositioning an existing diesel fuel tank air vent. Originally, this lengthy plstic tube terminated to air via a mesh-screened 'nipple' protruding 3/4 inch from the rear deck - where from time to time it would likely be swamped by solid water.
I could mount it up inside the hollow grp stern coaming, on/crossing the centreline. But, would I be better keeping it all inside the stern locker 'upstand' - or protruding as before, but about 3-4 inches higher?
Thoughts?
The trick is to put an inverted U in the pipe before exiting ...
If you can get to the pipe internally - you can add a length to create the U .... no need to replace the whole... and you can still use the existing fitting.
We need a picture.
Was the vent vertical on a deck? I doubt that, as rain would go into the tank.
Was it on the transom? You could use a U, as Refueler suggested, but it must be high enough to prevent impact pressure from driving the water over it, and it must self-drain overboard.
(This type of transom vent has internal baffles to kill the velocity and a built-in U to resist slap. Common on powerboats. $25.)
I would NOT terminate it anywhere inboard. Reasons given.
Yes, that is what I have. The loop goes up to nearly the height of the coach roof , significant higher than the filler, then down to the gauze fitting which is under the side deck, not overboard. Has never leaked any fuel into the boat after 30 years of sailing.
We had a 10mm tube connected to the bottom of the tank, attached to a bulkhead parallel to the tank (vertically), with a tap at the top, usually left open, and terminated well above the top of the tank. The tube gave the fuel level, marked in 20l intervals, 200l tank.
the filler point, tube, tank and tap were all adjacent to each other and you knew exactly when the tank was full.
Our tank was fibreglass, and moulded to fit three sides round the mast support (centralising weight). The tank was in a locker with no access to the accomodation.
Jonathan
Jonathan
mmmmm what has that to do with OP's question ?
Our was an overflow, a vent and means to measure fuel volume in the tank, all contained in a locker. Open the locker lid and you can access the file inlet and monitor the refilling of the tank. As long as the locker is isolated from the accomodation you don't need the a device out in the open, just a simple transparent pipe. You could spend money on thinwater's answer (but you would need a fuel gauge), Zoidberg is considering a simple pipe, internal to the locker and external to the tank held in the locker) - just as we had - and for 25 years it was faultless. Our fuel cap was a vent, belt and braces.
It might have no application to Zoidberg's question but we did not merit a photograph so had to guess.
Now what did you suggest....?
Jonathan
Jonathan
Post #3 ....
OP is asking based on his worry that solid water may enter the vent .... reasonable concern. His query goes on to ask if moving it to inside a locker ...
But all based on reducing risk of water entering the tank.
My post #3 gives a quick simple solution that needs no move of vent .. no drilling any other holes ... just a simple extra length of pipe added to give the inverted U which will solve the matter ....
As regards overflow - I assume like most boats - his filler point is on deck or external - so any overflow will not be contained in locker ... and means that moving his vent will not solve that matter ...
The filler is usually above the vent, so the vent will purge first on almost all boats. Fuel pumps should cut off if the filler fills.
Well I stand corrected then. Perhaps it's a modern AWB thing to have the filler on deck and breather on topsides. I've never seen it any other way :)
Arguably that says it should go inboard so that you can clean up your diesel spill rather than pollute the sea. I realise that’s the traditional answer but it’s not a good one.
If you want to control overboard spills there are many answers (just a few, below). Spilling fuel (or worse, gasoline) inside the hull is not one of them.
I have a Raycor. Works very well. I've tested the Cleanway; a little combersome, but very effective. ABYC requires an installed mechanism to prevent overfill spills through the vent on all covered new builds.
Racor Lg100 Lifeguard Fuel/Air Sep.Gas/Die
Prevent Marine Fuel Spills, Fuel Overflows - Clean Way Fuel Fill
Taking the Spill Out of Fill-ups - Practical Sailor
We need a picture.
While some have been basking in wall-to-wall summer sunshine, at this end one has been enduring 40-knot wall-to-wall winter drizzle. There has been quite some reluctance to clamber under the boat's tarpaulin - dribbles and runs of cold water runoff down the back of the neck - to delve among the shelves for the battered and distinctly well-worn filler vent thingy.
The team nagging finally won. Here it is....
It WAS mounted vertically through the narrow aft deck, where it was physically vulnerable and likely to be inundated in heavy weather. That space is now occupied with something more important, hence I need a new and better home for something similar.
There's an existing flexible plastic pipe, and I could readily extend that as suggested above. I'll seek a space where I can effect a 'vent loop' as high as practicable.
The thingy needs a good clean, wire brush would be a good start.
In an, many, emergencies - what could be more important than a reliable engine (with a reliable source of fuel). The filler vent thingy worked for decades, could never have been overwhelmed by seas - or it would have been moved decades ago.
A picture of the tank, its location and the filler cap would complete the information required.
Am I right in thinking you don't need a vented loop if you have a standard, yacht, filler cap. The filler cap should include a vent in its design and commonly is installed on deck where it is constantly inundated with water in heavy seas,, though I'm all for belt and braces.
The implications seem to be, there is no standard vented filler cap in this case - and/or the thingy is simply a diversion to simple and clear thinking.
Maybe what is needed is a cheap and simple, flush plastic filler cap that fits the existing filler pipe, or the tank needs a completely new filler pipe with a vented cap. Filler caps are often 'almost' flush with the deck, so they are not a trip hazard.
But maybe in my ignorance .... I have it all wrong.
Photos!!
Jonathan
My several filler caps for fuel and water are all flush mounted on deck. They are screwed down tight with 'rubber' O rings to prevent any ingress of water. The vent pipes are a couple of feet higher up, mounted on the sides of the deck saloon, well above any possible water level.
On boats without deck saloon the vents are generally on the sides of cockpit coamings or on the sides of the coachroof.
I can't envisage a type of flush deck filler which could also incorporate a breather.
If you google you will find all sorts of filler and caps to meet every need.
I chose this one 'cos its cheap (and I assume it might be available in Europe) as its marketed by Plastimo.
Plastimo Plastic Fuel Deck Filler With Vent Silver | Waveinn
Our filler and cap on Josepheline was flush mounted, had a vent and worked perfectly when the seas were breaking over the cabin roof.
Many fillers, but not all, with cap, claim to incorporate a vent within the flush mount of the device though I noted one device had a spigot (suggesting the vent was a hose).
Jonathan
