Irish Rover
I had a problem with water in one of my diesel tanks at the end of last year Engine Problem - help please. The engine has done over 100 hours since without any issues until last Thursday. I was on my way home from a week long trip and I encountered very rough weather and took a fair buffeting motoring into big waves at around 7kts. I usually motor on just one engine but in heavy seas I use both. Around 45 minutes after starting the port engine it stuttered a bit and then shut down. I didn't try starting it again and continued on one engine. When I was able to take shelter I had a look in the engine compartment and saw nothing amiss. No leaks and engine oil and coolant level normal. I decided to be cautious and continued home on one engine. I did start the engine in the marina for maneuvering and it seemed to run ok. I asked my mechanic to come have a look and when he revved in neutral the engine stuttered and died. Fuel starvation and on inspection the first inline filter was clogged with a snotty mucous type substance. He changed the filter and the engine ran smoothly. There was no water or contamination in the racor separator. I took the boat out for a spin this morning and ran the port engine for around 1 hour. When I checked the filter had a build up of mucous again, though not as bad as the first and the engine ran smoothly.
Diesel bug is not common here in Turkey and the mechanic suggest that changing the filter regularly for 3/4 turns should solve the problem. I'm not convinced and plan to treat the fuel. Because bug is not common here there isn't a huge range of popular treatments available. I found a PBO article from 2016 12 diesel bug treatments tested - Practical Boat Owner and searched for the products they tested. The only 2 available are
Grotamar 82
was developed to combat problems from low-sulphur biodiesel blends, and achieves its aim well. The 92% kill rate is good, and the sample proved the swiftest of the biocide-treated fuels through the filter. The product did a good job of dispersing the water into the fuel, although this is not its primary purpose. There were some minor deposits left in the bottom of the flask.
and
Star Tron.
Among the best on test with a 96% kill rate, Star Tron also excelled with a 47% improvement in filter speed. However, it did leave some sticky deposits in the jar and had not completely dispersed the water. Starbrite say that their product is most effective when the boat is used, as the engine will then process the treated fuel and destroy the bug.
So my questions
- does anyone have any experience of using either of these products or which would you recommend I use?
- for the shock treatment should I dose the remaining fuel in the tank [around 30% or 120L from a capacity of 400L] run the engine regularly for a few days and then fill the tank while adding a maintenance dose or should I add a shock treatment for a full tank and fill the tank now.
- any other suggestions or recommendations.
Sorry for the long post and thanks for taking the time to read it.
Grotamar 82
and
Star Tron.
So my questions
