ProDave
I have posted before our boom has a bend in it (it was like that when we bought the boat) We have now acquired a replacement second hand boom but it is too long and will need shortening. It sounds simple to cut an aluminium boom (having removed one of the end fittings) but we want it to be a neat cut.
The most obvious to me tool to use is my chop saw. It uses a 210mm diameter blade with a 30mm mounting hole. The finest blade I presently have is 48 teeth, that is a total of 48 teeth around it's circumference so 11mm tip to tip. But the blade says it is for hardwood, softwood, chipboard or other composite materials.
It is possible to buy a blade for this saw that is rated to cut metal but it costs about £60 and still only has a total of 48 teeth.
So what is likely to go wrong if I use this hardwood blade to make 1 cut in an aluminium boom? So I guess the question is, has anyone tried something like this?
I see plenty of joiners cutting aluminium window sills etc with these "wood" blades without issue.
