Concerto
If using a power saw to cut aluminum, then you should be using a ZTR blade. This has a blade with 3 types of tungsten tip. There will be a left and right tips and then a center clearing tip.
You mention the saw blade is 210mm diameter. That will only give a maximum of about 80mm. Unless it is a very small boom, your saw will not cut through the boom without rotating it. This would be dangerous as when cutting aluminum it should be clamped as it is far tougher than wood and more likely to snatch. So use a hacksaw as already recommended.
