Cutless bearing
BabaYaga
19 Dec 2008
Sweden
As the gap between shaft and housing is fixed, thicker brass means thinner rubber and vice versa.
We need some expert input as to the pros and cons please.
That could be interesting. My guess is that thickness of rubber is not over critical.
For 25mm shafts, Tor Marine makes brass shell bearings for housings with IDs 31.75, 35.0, 38.1 and 40.0. Most likely the ballast will be rubber, but the thinnest one probably also has a thinner brass shell (BTW they call that series 'English type*).
Tranona
10 Nov 2007
That is correct. Imperial sizes (both UK and US) had 3 or 4 different housing diameters whereas metric originally had mostly one size, although 30mm has a choice of 40 or 45mm outside. Many UK boats were fitted with metric shafts so there is a need for metric inside with Imperial outside. see here lakesterngear.co.uk/catalogue.pdf. The bearings are actually made in Holland, but UK manufacturers such as Montrose offer the same.
rogerthebodger
3 Nov 2001
. . . for P brackets 😉
Yes so where is he cutlass bush that the OP wished to remove.
A extended version of thi can be used to remove cutlass bushed from a stern tube as I did with my previous long keep boat
My current boat dos have a P bracket but also a bush at the aft end of the stern tube
All that needs is tto remove the stern seal and ft the device down the stern tube which is easy as the OP has alreadc remober the pron shft so the all thread can pass down the stern tube
Neil_Y
28 Oct 2004
Devon
www.h4marine.com
I may be biased but we supply composite bearings to a wide range of commercial and leisure vessels. The bearing material is composite (no rubber) The tubes of raw material are machined to suit the type of fit you want and waterways are added. In practical trials Maritex lasted at least three times as good rubber bearing, we also see less shaft wear. There are a few theories why that is.
Each bearing is made to suit the shaft and carrier of the vessel. We advise using a clearance fit bedded on epoxy, you can slide it in by hand and turn it. Epoxy softens with heat which aids removal. It's important to understand that a bearing made for a clearance fit or alternativel an interference fit are actually made a different size. With a press fit the bearing is squeezed and the ID is reduced so the finished size will be a larger ID than a clearance fit.
There is no standard length or size of ID and OD as they are made to suit the carrier and shaft. The composites we work with for marine use are phenolic based fibre reinforced that have lubricants in the matrix and also some materials that may reduce marine growth. This is what they look like.
Poignard
23 Jul 2005
South London
That's useful information Neil. Thanks.
How do prices compare with the usual rubber cutless bearings?
What's the lead time?
For example, my rubber cutless bearing is O/D 1-1/4" I/D 1" Length 2-3/8"
billyfish
6 Oct 2020
What's the company Web?
Neil_Y
28 Oct 2004
Devon
www.h4marine.com
Nominal 25.40 x 31.75 x 60.3 with three waterways £41.73 ex vat... but as they come from a factory in Australia we would wait to send it when we have a batch to ship at the same time. Exalto UK can supply them. If I do one off the shipping charge is huge but Exalto will probably be cheaper as it will go in a box with other orders for them. We send batches to exalto every two weeks or so. Most of it bearings for water pumps.
Poignard
23 Jul 2005
South London
Thanks a lot. I have made a note of this for when I next need one.
