Cutless bearing
billyfish
6 Oct 2020
Hi , I got the prop shaft out yesterday and I'm going to attack the dreaded cutless bearing today, but what is the best make to replace it with, don't want to do it again anytime soon. Thanks
Tranona
10 Nov 2007
choice is between either a brass shell or non metallic, usually phenolic or GRP. Bearing lining essentially the same so no difference in potential life. Non metallic is claimed to avoid potential galvanic action but the probability is low and brass is probably more commonly used.
Tranona
10 Nov 2007
Cutless bearings come in standard lengths (100mm for 25mm for example) and housings are usually made to the same length
Tranona
10 Nov 2007
Don't forget you probably have another bearing at the stuffing box end
Actually that is quite rare these days. Most shafts are floating in the tube with just an outer bearing or a P bracket. This allows for more potential movement for the engine. It is possible with some tubes to fit a bearing on the inboard end. I have just done it on a stern tube that had a solid stuffing box housing screwed onto the tube rather than the more common hose mounted stuffing box. This is the second time I have done this modification but to make it work you need a very good flexible coupling such as the Vetus Bullflex I used. The reason I did it is that the shaft is very long (1.6m) and I wanted to use a Volvo type rubber shaft seal rather than the stuffing box and a shaft that length needs an intermediate support.
BabaYaga
19 Dec 2008
Sweden
I have replaced twice on my boat, both times with brass shell bearings, but different makes. What I have found is that the thickness of the brass shell can vary greatly between makes. First time the brass tube was quite thin, last time it was substantial. Much prefer the latter, as I have to hammer it in into the stern tube. This was made by Tor Marine.
fredrussell
24 Mar 2015
To get old one out use a reciprocating saw with long blade for metal in. I did mine using hacksaw blade - took an age. I’ve since learnt the pros use reciprocating saw.
Poignard
23 Jul 2005
South London
I removed the bearing housing and pressed out the old cutless bearing using studding, nuts and suitable sockets.
I thought I might as well take the opportunity to renew the sealant between the bearing housing and the sternpost.
