creosote
alienzdive
4 Jan 2005
London
Chilli powder and commercial weed killer in emulsion paint.
Would never be such a cheap skate myself, but that should answer your question.
ccscott49
7 Sep 2001
I used chili powder in my last antifouling, (1 kilo per 20 litres) so I'll keep you posted as to it's effectiveness. Seems good so far.
Emulsion would not last very long on a boat, moving through the water.
But, in the far east, thats what they do, but not with emulsion, they use some other paint.
TrueBlue
30 Apr 2004
Sussex
Re: creosote - where
Creosote is alive and well - less the toxic bit - and is sold as creosote substitute.
Can be bought at Homebase, Focus and B&Q. Both hide it away where it's not easy to find, 'cos they want you to buy more expensive less effective water based preparations.
I've use it on a rope button this year and it still smells of creosote - so I assume it is still effective.
VicS
13 Jul 2002
Real, coal tar, creosote is still available for professional users but banned for amateur use. See here
m1taylor
28 Apr 2004
South Devon
I used some of this 'substitute' creosote the other day on a shed. It's rubbish compared to the original - the wood will need much more of it, more regularly. So in banning the original, you have to slop twice as much rubbish on twice as often. Makes sense doesn't it!
VicS
13 Jul 2002
Re: Creosote
I don't see how you can judge the substitute based on that. You should carry out a long term test, under controlled conditions, of its preservative ability compared with that of traditional coal tar creosote. Failing that at least compare its analysis for phenols against the British Standard for coaltar creosote.
Coal tar creosote has been banned for amateur use because recent research has indicated that the benzopyrene in it is much more carcinogenic than previously thought.
So it has been banned to protect the health of you and your family, not to relieve you of more cash.
You will find some info here: http://www.dti.gov.uk/ccp/topics1/facts/creosote.htm and sheds more elsewhere if you do a Google search.
It looks as though I should have disposed of the last of the coal tar creosote that I personally tested in the lab. for compliance with the British Standard. Just as I did with the Halon fire extinguishers, the spare refills and the TBT antifouling back in the eighties.
ducked
6 Oct 2024
Should be fairly easy to make. In crude form its just a destructive distillate of wood, coal, oil or all three. I believe the coal-derived stuff is the most toxic, which would seem to be what you want in this context
The environmental damage would be between you and your conscience, but the scale you might be doing it on is going to be insignificant compared to the professional polluters (that might still be licensed to kill.)
Round here there's still a bit of sea coal comes up on the beach, probably enough for this purpose.
Whether its worth it is a different question. I doubt it'll be very effective as an antifouling since I think creosoted wood piles grew stuff on the surface fairly quickly, though the bulk pressure treated wood remained preserved.
As a wood preservative, say in the bilges, it'll likely be somewhat effective, but messy, and you might end up having to sleep with it, and/or the fishes.
If I had a wooden boat I'd be more likely to try it.
2Tizwoz
23 Jun 2005
Northumberland
There isn't a similarly effective product with the result that timber fence posts no longer have a satisfactory life. Farmers are turning to steel Electric companies are able to use creoste for their overhead lines as people don't regularly come into contact with them..
Graham376
15 Apr 2018
Diesel and old engine oil mix works pretty well on fence post bottoms if left to soak it up for while.
Irish Rover
5 Feb 2017
Türkiye
I think I was addicted to creosote when I was young. There was a railway yard not far from us, and I'd go there to sit on a pile of sleepers for hours on end. A friends father worked on the railway and they had lots of old sleepers in their garden. We made a fort from them and it was another one of my favourite places.
Thistle
2 Oct 2004
Here
Thinking back a few(!) years, there was always an old boat berthed in the local harbour. It had been converted to hold tanks of some tar/creosote concoction which the fishermen used for nets and the associated ropes which were periodically dipped in the goo and then hung out to dry.
The wooden boats, on the other hand, were always carefully painted with multiple layers of oil-based paint.
If it was good enough for them ... .
Refueler
13 Sep 2008
Far away from hooray henrys
Many 'Dachas' here are built from 'retired' Railway Sleepers ... even the house I'm in has its main wall construction from untreated sleepers (1908) ... then clad. Its warm in winter and cool in summer.
Refueler
13 Sep 2008
Usually in the 'old days' ... ship stuff such as wires / cables etc were dipped in Ferroil (waste Whale oil based and then later some other base) or where standing rig - White Lead and Tallow... Cordage would be Tar ... with hulls often given a coat of Stockholm Tar before overlaid with conventional coating.
