Pye_End
Hopefully ok, but well worth a critical look at top and bottom stay attachment points (inside and outside the boat if possible) for forestay and backstay.
His hands are still shaking, most likely.I don't think he can post photos yet.
You can even see the special bent shackle for the halyard,on the swivel. That convinces me that it is a Plastimo.As far as one can tell from the photos it looks very much like an older type of Plastimo system. Some close up photos may help to positively identify it.
It depends to some extent on the tabernacle. It looks as though yours is the smaller kind (although hard to see in the pics). The one I had and that OP has have large plates a foot or so up either side of the mast with a 12mm bolt right through to pivot on and another to lock it off. This setup held the mast very well in the centre and although it did wiggle along its length a little it never went sideways even unsupported. I've also used a less substantial one previously and would be far more careful in that instance as you say. I never used poles or frames for lowering as it was so secure, and with one end fixed it was possible to walk it back and just hold the weight.stop it swinging to side as mast lowers
… Any ideas on how to replace the foil on the forestay for a Halcyon 23? I believe I can release the forestay by easing pressure on the backstay by loosing the nuts whilst also rigging up a rope to tie to the anchor cleats and to the mast to hold the mast in place. Will I also need to detach the whole furling system from the top of the mast to drop the dented foil down so that I can remove and replace it? Any ideas on costs I could be facing?
What could possibly go wrong.I would say that at 23 ft it would be marginal if not foolish to try to climb the mast. The boat will not have enough stability when on water and your weight up there.
Basically, Offshore Yachts no longer exist. But the concept of "parts" is wrong anyway. Offshore would buy standard parts from makers of spars etc., so that's what you look for. It's not like cars, or even close.Anywhere that specializes in secondhand boat parts particularly for my Halcyon 23?
Thanks for all the comments so far folks, I will be taking the advice you have given me and I will be lowering the mast on to an A frame that I will put together. I am not gonna do this yet as I want to move the boat out of Cardiff Marina to her new berth in Uphill, Somerset first. I plan on motoring across the Bristol Channel at some point this month when I get a calm day and good tides. I have had to replace the water pump with a standalone electric pump after seeing the pump that is a direct replacement is around £500 and like rocking horse s***. So I will be running the girl in Cardiff Marina for a few hours to check engine is being cooled and not over heating before I set out across the channel. Once she is in her new home then I will look at replacing the pump with an original part. The engine is a reconditioned Yanmar YSM, so I may even go for a newer engine fitting at a later date.
My next question, where do I buy new sections for the foil? Are they pretty standard and cut to fit? I assume I will have to take note of the track that the cars connected to the genoa run up? Anywhere that specializes in secondhand boat parts particularly for my Halcyon 23?
She's a pretty little boat and I am happy spending money on her even though I will never recuperate the money back. She is my practice boat before I finally upgrade in a few years when I retire and go off to cruise the world.
Hi, If you could dropbox me it that would be great thank youThe 608 uses same as the 406 and other Plastimo of that series. The foils should be interchangeable.
Do you have the manual ? If not - then I can 'Dropbox' it for you ..
Thank you
I have wired it up to ignition so it turns off when I turn engine offJust a thought, if you temporarily fit an electric pump make sure it is turned off immediately the engine is stopped.
