John100156
Thats a nice looking F43 in the background...... Now I know where the two buckets of grey dust that we cleaned off came from.....
I hope you have better experience with Propshield than I had in Majorca when I applied it to my old Ferretti 46 props and I had it applied by so called 'professionals'. Within weeks it was flaking off in sections and those sections were becoming barnacled. When I tried to scrape the barnacles off those sections, it was too easy to damage what was left of the Propshield treatment. In my case a very expensive failure.I expect the Propshield and Lanoguard to wash off almost immediatly but I'm hoping that a small layer may stay.
Yes you're right. SorryI think you are mixing up Propshield with Propspeed
Thats v reasonable and makes it a no brainer really. Damn, I've just paid an Italian yard €2000+ to re-antifoul my boat. I wish you'd posted this a month agoPrices ranged from just under 4000 euros to around 5500 euros.
Inclusive of VAT (IVA)
That was including all old antifoul removal, supply and application of the Coppercoat to boat and metalwork and preparation of the props (I polished them). Any metalwork to be Coppercoated was initially primed with the official Coppercoat primer.
A typical antifoul session (Micron 77) would be 2000 euros inc prop treatment although I have been quoted more.
Thats v reasonable and makes it a no brainer really. Damn, I've just paid an Italian yard €2000+ to re-antifoul my boat. I wish you'd posted this a month agoI assumed the treatment would be around €10k. It'll have to be next year
I've decided to take the plunge too. Boat is being copper coated at the end of the month, same people that did Jenny Wren I believe. I'm after the smooth bottom to get a more reliable performance and not having to scrape and paint each year. Last year I had the boat lifted and jetwashed 3 times (again I can get cheap lifts - 200Euro for a lift and good jet wash) using normal antifoul so if I have to do similar with copper coat I will still be ahead after a few years and not have a build up of antifoul to deal with. I have been using the epoxy based spray on antifoul on the metal work to keep the props clean - it works well in my marina and stays on too.
A fantastic thread - thanks for posting.
Coppercoat is a (albeit water-based) epoxy. OP - has it helped to slow anode wear on your boat?
More generally (and leaving props to one side) is it better to cover the stainless and bronze shafts/p-brackets/rudders or leave them uncovered?
I'm going to go down the Coppercoat route, and tempted to cover everything over and then connect everything to the shafts and rely on shaft anodes alone (which can be changed without a lift).
Do you mean more slippery?And I still believe that when it is clean it is more efficient than conventional antifoul.
