Elessar
Re: Epoxy coatings (either before CC or normal A/F)
yep I'm pretty sure that's the one they use.
I used to use a bit of the epoxy itself mixed with something like west system 409 microspheres in it because it's easy to sand. If its a corner or something use something harder like colloidal silica.
Once you've done the first coat it will often show imperfections you've missed, you can fill between coats too it will all bond together. (can't sand between coats though it won't be hard enough)
Thanks a bunch, Elessar! :encouragement:
Just a couple of last (hopefully...) questions...
1) I googled a bit in the meantime for 3M epoxy & Coppercoat to find the exact 3M resin type, and I found several references to GP120, but apparently that's mostly meant for steel hulls.
Is there anything else which is better suited for GRP?
2) What would you suggest as a filler for minor repairs, before the 2 epoxy coats?
TIA!
