MYStargazer
Wear on anodes
Actually, I want my anodes to wear - thats what they are there for.
I don't know the construction of your galvanic protection but I've always been concerned about shaft anodes.
IMO, a good galvanic system should have a good Nobel difference between the cathode and the anode with everything else in between.
It seems to me that shaft anodes are half way through the system which IMO will create an electrical flow both ways down the shafts.
If that is exactly what you want, it seems to me that is what you will get.
Personally, I would stick to convention.
That is big hull anodes bonded to the boat's earth system and then ensure that there is an excellent electrical connection between the boat's earth and the shafts.
That way you will create a good electrical flow between the anode and the cathode (the props) - BTW I'm never sure which way the electricity actually flows but it is the concept that matters.
If you are asking about coating the underwater metalwork with Coppercoat - it was a failure on our boat - it didn't stick.
Great on the hull - just not right for the metalwork.
Back to your original question, I don't think that Coppercoat has much bearing on the galvanic system.
Coppercoat is copper granules suspended in epoxy - I'm no expert but it seems to me that the epoxy surrounding each granule will electrically insulate it from the next.
Anyway, as I say, sacrificial anodes are designed to wear to protect other more expensive parts - thats why they are called sacrificial.
Some more really interesting insights - thanks very much.
At the moment, like you (albeit on a more modest scale) I have two hull anodes protecting two stainless shafts, mild steel p-brackets, bronze props, bronze rudders and stainless trim tabs. Quite a mix of metals. I'm replacing my old bronze sea cocks with Marelon (Nylon/carbon fibre mix) so that's at least some less to worry about.
Interesting theory about shaft anodes being in the wrong place mid-circuit. I can see the logic in this, but I'd be fascinated to know if there's any science behind the idea.
I've been playing with the idea of virtually entombing the rudders, p-brackets and trim tabs in West System epoxy before coating with Coppercoat. Maybe this will both reduce their galvanic exposure and help the Coppercoat to stick...
