Cret
Just about to buy one of these boats and was wondering if anyone has any info about them or owns one themselves?
It's a 1986 built open console 18' boat. Seen one or two around before but don't know a lot about them really. Really like it though and it looks ideal for what I want at the moment (and its cheap!)
Here's a pic:
Comes without an engine. I currently have a 1999 F50 yam to stick on if I want but I was wanting a bit more oomph than that for various reasons, and am planning on a BF-75 Honda that I've seen for sale at a good price.
According to a mag review I bought online it states that 125hp single or twin max hp is the limit for this boat but the transom doesn't seem all that meaty to me that it'd take something of that size. I'm certainly no expert, but was wondering if it'd be sensible to get a stainless plate made up do go over the transom and help spread weight/reinforce. Maybe that's daft since the engine intended is less than recommended limit.
Is there any sort of rule of thumb of thickness for the transom for a given engine size (I realise that's over simplifying things somewhat!)?
I got information from Coastworker themselves which suggested that 90hp was the max, although they didn't have the knowledge of what model year it was at that point, so maybe the mag was right since I think they had got this as a test review boat at the time and must surely have had to state the correct spec.
Either way, I'm hoping a 4 stroke 75 will be fine despite its cumbersome weight of about 175kg compared my F50 at 113kg.
I was wondering though if anyone knows what sort of weight an equivalent 2 stroke motor would weigh?
Don't want to get the engine bought and fitted then find that despite the transom being rated for the power that the weight of a 4 stroke (since they weren't around at the time the boat was brought out) 75 makes the back end site really low in the water or whatever.
Which takes me to the next point. The hull is apparently self draining, and has two drain holes in the transom accordingly.
You can see them here (just under the start of the name, and by the wood bit on the ladder):
These seem to allow water on the deck to drain out through them, and I believe are meant to be above the waterline. The boat has a big area beneath the deck that can't really be accessed except a couple of small hatches and I believe has a load of bouyancy under there. Presumably the hatches ensure that any water that does get into the boat, doesn't end up in the bilge, and just drains out the back.
I think my potential concern here is engine weight related again, ie that these drain holes look very very low already and I can't see how water wouldn't come in even with a small motor fitted, never mind a heavy one where I can't imagine the holes wouldn't end up sitting below the waterline.
Might be being a bit paranoid, but even though I'm looking at an engine well in the spec of the boat, this sort of thing makes me slightly nervous since I've not had anything quite the same on previous boats and don't really know what to expect.
Anyone with a similar self draining sort of boat able to put my mind at ease here?
I know you can get things called scupper valves/flaps, but how well do they work at keeping the water out, and is it worth getting a pair and adding them to help keep the brine at bay?
And worst case, if the new engine does cause these drains to sit below the waterline would I then need to plug them or something? Presume otherwise I would soon have a deck swimming in seawater!!!
Thanks for any info if anyone can help.
Here's a pic:
