Baggywrinkle
With our kids I did a simple test. If I grabbed a properly fitted jacket by the lapel, shoulder or waist belt and lifted them off the ground - if they could wriggle out, the jacket was a fail.
The 150N kids' jackets are usually air/foam, rather than all foam. More usually, kids' jackets are all foam and 100N.
If overboard in a breeze, they'd be blown all the way to france, like an erant li-lo!
But the manufacturer says they do have crutch straps. Who would you believe?
I have always paid a lot of attention to posts and magazine stories about man overboard drills and I have a system figured out on my boat for using the spinnaker haliard and winch etc to get a person on board again.
Last weekend I sailed in the Solent (beautiful!) with my two grandchildren aged ten and eight who were fitted out in the new approved lifejackets (one 'Spiral' and one 'Baltic') their parents had bought for use in their new Rib. They were bright orange affairs with big collars and zip-up fronts. You see them on kids everywhere.
I got to wondering as we drifted along in the sunshine how I'd get one of them back on board. My freeboard is not great and I can touch the surface of the sea with fingertips if I kneel down and stretch but this wouldn't help much.
There is nowhere to hook them with a boat hook. There is no loop strong enough to clip or thread a line for lifting or keeping them on board. No crutch straps so if I pulled them up by the collar there's a good chance they'd slip out. I came to the conclusion these approved devices are scandalously inadequate. Yes, they'd keep the wearer afloat. But they'd contribute nothing to his rescue unless, perhaps, you were in a Rib or dinghy.
I'm not talking about mid Channel in the middle of the night, when you'd definitely click them on by way of an extra harness. Under sail I make sure they stay in the cockpit in any case. If I had a dinghy towing astern I'd certainly use it but usually I leave it on the buoy. In fact, even my dog is better protected than the kids because his lifejacket has a carrying handle or loop that can be picked up by a boathook.
An incident is most likely to happen on a quiet sunny day because that's when you relax and let the kids sit up front, and so on. So what would you do? How would you get a child back? At this moment I have no idea.
Any thoughts?
The man who has the lifejacket?
Or are you suggesting that he is either lying or hasn't noticed the crutch straps?
Maybe they are removable and got lost, maybe a naughty child cut them off or perhaps even the manufacturer changed the spec to keep costs down.
Perhaps you should just tell the OP that he has got it all wrong, he is worrying unnecessarily as he is clearly mistaken over the crutch straps and the "lifejackets" his grandchildren are wearing are more than up to the job because you've checked it out on the internet.
Yes I do and she's far better at it than you. Is that the same way you let you wife know you got it wrong without actually having to admit it?Sorry, I didn't realise you only wanted an argument. Don't you have a wife to argue with?
I haven't got it wrong. If you'd bothered to read my first post in this thread, you'll see I wrote "The Crewsaver Spiral lifejackets are supposed to have crutch straps as standard, so is it possible these had been removed?", a possibility you've only just realised.
I think you'll find they do.
s I understand it these are lifejackets (not buoyancy aids) with BSI Kitemark. They are new so it's unlikely that the crutch straps just disappeared. I will check them again when I go down to the boat at the weekend and post further.
Of course the rubber dinghy solution is best and a good reason not to leave it on the buoy. And the bowline under the arms sounds good but I think would be rendered nearly useless by the padding effect of the LJ's.
I am not suggesting the LJs are useless or dangerous but they are certainly less than fit for purpose in my opinion.
