Refueler
No ... just that if you fell in - you'd at least have been happy immediately before it and not know much about rest !Kind of makes the thread pointless then.
I should up the game a bit as well, added "get harness prepped & ready" to the "Before leaving" checksheet & think I should randomly just wear it now & then even, or maybe more so, in completely benign conditions. Logic being not to practice clipping off so much as to train the brain into seeing wearing it as a totally normal part of being on passage instead of somehow linking it with heavy weather.
Also, imho, all these systems & practices should not be classed as some kind of "this is how it's done" but rather as constantly evolving things which can and should be given a bit of thought along the way to see if there's a better way. "The way it's done!" should only exist for the there & then and be thrown out if and when something better comes along.
It would seem the reality of trying to get someone back on board is not even close to practicing it therefore is it really worth practicing as there are so many variables.
I came across an article where a decent sized yacht threw a crewmate overboard to test mob drill. Can't remember the exact time but it was something like 35 mins to get him back onboard with a fit experienced crew in the solent. The conclusion was dont fall overboard at sea, you will die.
Who said anything about there being only one method used?On the second approach perhaps a different method would make more sense, one where they are hove to. Se how that works. In fact, the students need to learn more than one method.
Many years ago there was a recovery device advertised in the UK that did just that - without the need to handle a big sail over the side. Wonder what happened to it.I have always maintained that on a sail boat - one of the best recovery tools - is the sail ... remove sail from groove .... pole out halyard to side so sail is in water .... but sail still made fast onboard ... get person into sail - haul up halyard to 'roll' sail and person on board .. no need tackles or fancy stuff ...
A reasonable suggestion, except that boat would happily jog along at one to two knots when hove to in normal conditions.On the second approach perhaps a different method would make more sense, one where they are hove to.
.......MOB Lifesavers | MOB Retrieval for lifejackets
I have no association with the seller or developer beyond being a customer. I have fitted to all 8 of my lifejackets and will fit to crew who bring their own. My wife can recovery all 14 stone and 8lbs of me, plus wet clothes, effortlessly, using just one hand if necessary.
In fact, even those with leg loops, the loops meet no lifting strength requirement. They are required to hold the jacket in place during a jump into the water from 3 meters and while in the water, but are NOT required to meet a lifting or fall strength requirement. Often they use plastic buckles and occasionally fail during drills. The harness standard, ISO 12401, does not have a requirement for leg loops, and thus there is no strength requirement.As I read it, the big problem with this product is a LJ is not a lifting harness. Or should I say the majority of LJ's are not designed for lifting a person. Slipping out is one possibility.
But, imho, going back to the first post - only after you've done every last think you can realistically think of to stay onboard in the first place.Buy a lifesaver, they are about £20, try it in the water, get lifted out using a halyard. No need to take my word for it.
Interesting bit of human psychology that even on a web forum everyone veers towards the exciting what to do when disaster strikes and things happen rather than slightly vague not so interesting how to not fall in when nothing happens..
