rogerthebodger
I did wonder about a relay, but wasn't anxious to add the extra current. Nosing around the internet, it does seem that relays are available that draw a few ma, so I'd still be better off than the original light with its bulb, They're designed to be mounted on a PCB, but I suppose I could solder the wires directly or, perhaps better, use a bit of stripboard, which I reckon would be more robust.
Is the switch a 3 position switch if not you will need a switch to switch power to the switch otherwise one or other light will be on all the time
Buyers 6391103 Rocker Switch,Round,Black,On/Off/On | Zoro.com
This looks like a similar type switch which is on off on that could be suitable
