kashurst
Don't worry, I have form on this sort of thing. I have done it before. I will be taking the interior apart very carefully and reusing the majority of the wood panels either as is or as templates for modified versions etc. The main bulkhead is staying exactly where it is. But the mattress is well beyond saving.Oh no ! Haven’t we heard lots of stories before about “I stripped the entire interior out”, but many fewer stories of “and put the interior back together”!
Launch it quick and start using it before this sickness (“project think”) takes root.
This week all the ceiling and wall linings will be coming out of the forward cabin. I want to see how much space above the intended panel height there is then I can select light fittings.
Then it will be a reconstruction of the galley. The existing galley design is a little odd, the cooker is quite high and the small fridge is on the floor.
Then the bathroom, and finally the main saloon. So I will be working my way out of the boat.
The goal over the winter is to create the new ceiling support structure and panels, do all the structural woodwork in the the galley and bathroom and clean up the wall panels that are to be reused. Once the weather warms up again I will start doing the painting and glue all the foam backed foam on. I will have to get a few of the future copies of MBY to see what colours and fabrics are in vogue for inspiration.
The boat has an Eberspacher heater fitted with a separate diesel tank. Every Eberspacher I have had (5) has been a dismal failure. I can't decide if I should test it in situ, or just cut out all the disapointment and frustration trying to get it to work and just bin it immediately. Any bets that this one will actually work?
