GregOddity
Good that you inspected each rivet and there is no stress visible, you should hopefully be ok, take a straight edge and lay it length ways along the mast accross that joint to check its flat before you chop anything off, if the joint is not flat you could at least completely remake the joint as you have an excess of length. The spliced joints can hide internal corrosion.
I am thinking of using an inspection camera to check the inside. I’m just curious to see if there are any signs of corrosion. I did check with a flat bit of aluminium and it was straight. It’s however still in my plans to check it again and make sure it’s all as it should be.
