jaminb
After watching Sam Holmes lastest video I have decided to rig a permanent boom preventer.
I did make a boom brake using a climbing figure of 8 belay but wasnt convinced as it only reached back to the mid point of boom and I thought it should be fitted as far aft as possible.
So i was thinking permanently install lines from the boom end either side of the boom held tight with elastic at the goose neck end. This would then attach to a non permanent line rigged through the bow mooring cleat on the appropriate side and then run back to the aft mooring cleat so it could be easily released when required.
However another though occurred, could I use the spinnaker pole down haul attached to the permanently installed lines? Would it be sufficiently strong (AWB bolted through the deck but behind a head lining). Obviously I would need to rig the non permanent line if the spinny was in use but this wouldnt be the case when the wind was strong and one less line to rig may be preferable in windy conditions.
Silly idea or worth pursuing? Thanks
