Boathook
bumblefish
22 Dec 2002
Brighton
I have an ash pole and a brass hook, what would be the best tool and technique to fashion the end of the pole for fitting the hook?
chippie
21 Aug 2001
Northland New Zealand
I have fitted one by turning my beltsander upside down in a 'workmate' type workstand and carefully rotated the pole to get the taper. Once near the correct size I rubbed chalk on it and offered it up; the marks on the chalk showed the high spots.This was a utility boathook made from dowel. If you are starting from a square piece of timber you will have to eight side it and then sixteen side it and then sand it to its final shape.
I once saw in american magazine a boathook that was made in such a way that it floated upright to ease recovery if dropped overboard. This was a good idea I thought, but hard to figure out the buoyancy issues involved.
I hope this is of some help.
aztec
10 Oct 2001
Poole Dorset
you can also heat the brass in a fire, and burn the hook onto the rough finished timber... it's also fun..
<A target="_blank" HREF=http://homepage.ntlworld.com/s.amos/index.html>http://homepage.ntlworld.com/s.amos/index.html</A>
aztec
10 Oct 2001
Poole Dorset
you can also heat the brass end in a fire and burn it onto the rough shaped timber.
