BartW
the accumulator is basically just a tank, not so different (also in size) from those used for diving.
OK I see,
now I understand.
The black box is port engine PTO and you can see port drive shaft under it.
Yup you can do that but you also have to match the rpm and power rating of the PTO with the pump you're bolting on to it which is why it's best to stick with OEM equipmentI wouldn't worry about flange fit and getting OEM gear. So long as there is a little PTO shaft accessible under a lid on the g'box, you just buy a bolt-on hydrualic pump and get a flange adapter custom made by a machine shop. And maybe a small jackshaft adapter sleeve thingy if you cannot match the splines. Few hundred euros at most
No it's not my specialist domain but I employ people for whom it isI believe that this is your specialist domain,
so whatever I do, I'll have it checked on here
Yup agreed. But hydr pumps will acceot a wide range of RPMs. And the power is fine - 1000++hp! Way more than the pump can ever absorb. Harder bit is matching the splines
Yeah but many PTOs cannot transmit the full power of the engine and neither can they necessarily supply the correct rpm to ensure that the hydraulic pump supplies the max oil flow required by the stabilizers. The stabilizers will require that max flow at a certain pressure which will determine the power requirement. The hydraulic pump needs to be selected such that it's power rating exceeds that required by the stabilizer hyd system and the PTO needs to be capable of transmitting that power and providing the necessary rpm. Its not just a case of bolting a hyd pump on the back of the engine or gearboxYup agreed. But hydr pumps will acceot a wide range of RPMs. And the power is fine - 1000++hp! Way more than the pump can ever absorb. Harder bit is matching the splines
I'm good for absolutely nothing according to SWMBONot much left where you're good at Mike
There must something, pls tell
Thanks but they hacked the original copy about a lot so I'm not happy about how it read in the endJust read the article from Mark F in YBW
Well done that man, nice article
It actually is, to some extent.Its not just a case of bolting a hyd pump on the back of the engine or gearbox
+1It actually is, to some extent.
Mmm, as high tech as a HarleyIn my boat, the stabs pump is belt driven (go figure!)
jfm, agree to disagree on this but if I was spending tens of thousands of quids on a stabilizer system, I'd want to satisfy myself that the PTO drive system could adequately provide the speed and power it needed+1
Mike you're introducing a bunch of factors that don't exist. All that's needed is to spec a hydr pump that supplies way more oil flow/pressure than you need becuase it needs to operate the stabs at low rpm and it will absorb only the power it needs. PTO shafts deliver way more than the power you'll ever need and as a matter of engineering their limitation is ability to supply torque not power because their breaking point is indifferent to the rpm and is sensitive only to torque
So what? It did its job for more than a decade and a half, and counting (touch wood!).Mmm, as high tech as a Harley
If one of my manufacturers (even the Italian ones) produced a machine with a belt driven hydraulic pump to drive its services, my customers would laughSo what? It did its job for more than a decade and a half, and counting (touch wood!).
Besides, all the maintenance it needed was ONE belt tensioning, 5 or 6 yrs ago.
That's more than can be said of even HDs in the bike world, I reckon.
(touch wood!).
