webcraft
My MG30 has a well or sump the size of a largish saucepan as the deepest part of the bilge. It is approximately 180mm in diameter and about the same depth.
Current bilge pump arrangements are one manual whale gusher with a 1.5" hose in this well.
I had hoped to fit an Orca 1100GPH fully automatic pump in this well, but it looks as though it will not fit. Although I could get it into the well (just) there would be no room to curve the hose from the outlet upwards.
Another option I had thought of is the manual 950GPH Orca model with a field sensor mounted alongside it. I believe there would just be room for this, though the sump would be pretty full of gear and so would fill up quickly in a seaway when water slopped out of the rest of the bilge into the sump. This would not be an issue when the boat was in a marina though, and the pump could be switched off auto on passage if this was an issue. Also, there is a model of the field sensor that waits 30 seconds before switching on to avoid over-switching in this situation, so maybe not an issue.
I want an auto pump as the boat may be left unattended in a marina for relatively long periods of time. I don't want it to cycle too much. Seaflo pumps would fit, as might a Rule-mate, but neither of these look particularly robust or have very good reviews. The linear Whale models don't fit either.
The Whale Orca pumps have very god reviews and the 950GPH model with a field sensor switch seems like the best option - anyone got any comments or suggestions?
- W
- W
