GHA
You need to back that up with data. High CCA doesn't mean "voltage doesn't drop much under load", Trojans are lead acid. AGMs are lead acid. If you want little voltage sag you need to look elsewhere than lead acid. Like LiFePo4.I saidd it does not care where the power comes from - just what it is. That is why you us a battery with a high CCA for a windlass - as suggested for the OP. No one has suggested using Trojans for this job so not a valid comparison.
You didn't look but if you did there's not much comes up immediately. From google scholar >
COMPARATIVE ANALYSIS
OF AUTOMOTIVE STARTING BATTERIES
IN THE ASPECT OF DIAGNOSTICS
RESEARCH
ANALIZA PORÓWNAWCZA SAMOCHODOWYCH
AKUMULATORÓW ROZRUCHOWYCH
W ASPEKCIE BADAŃ DIAGNOSTYCZNYCH
Apart from the used battery very little difference in voltage sag up to about 1C.
Time to shuffle those feet some more because you're wrong again....
