Caraway
Exactly what happened when a previous owner had a piston fitted to a con rod on my MG. They didn't manage to get it in the right spot and in trying to 'adjust' it damaged the little end piston bearing surface.If we heat to 110oC by the time the bearing has been taken off the heater armature, then slid over the end of the shaft and perhaps touched the cold shaft on its way down to its intended position they can stick before fully home.
They were intended by BMC to be fitted cold using up to 5 tons pressure and a jig to locate the gudgeon pin in the right place.
