PaulRainbow
Say a 2kW microwave for easy maths.
If you get a 105Ah LiFePO4 battery, that will give you about 1kWh of usable power after losses.
Therefore it could run the microwave for about 30 minutes before flattening the battery.
To charge the battery back up again you need to put about 1.2kW back in again.
With a 100W solar panel, in the middle of summer, you will generate around 10kW a month in the summer, and perhaps 3kW in the winter.
So it would kind of work assuming you only used the microwave for a few minutes at a time.
I would just take the battery home with you when you leave the boat and charge it up again.
Typical microwave for an 8m boat would be 800w, maybe 1000w. So at least twice as long from the battery than above.
As you say, would likely only be used for short bursts. If so, an additional SLA battery, in parallel with the current domestic battery/s would give enough power for a few short uses.
I would expect a 100w panel in a reasonably unshaded spot would charge the battery back up from a pretty depleted state in a couple of days.
@Victoriana A little more info would be useful, size of microwave, how much use expected, current batteries etc
