terranova
You are right about the fires .They have had two biggies .Before my arrival time in Loano end of summer 2019 there was fatality incident on a iirc 20-22 M FB German registered.They got trapped in the mid cabin no second escape route .
Since then the marina authorities do play the “switch the thing off if unattended line “
Maybe they have done a risk assessment and / or it’s driven by there insurers ? Dunno
There was another fire last yr a ferretti jumbo 100 or what ever …..u tube shows it started in the engine room .Thankfully no one was on board it just sank .Later the sunken wreck removed .
@ tera nova just dock walk and see what everyone else does .Some live locally and regularly visit.
When onboard in Loano ( summer season) I tend to burn through about € 4-5 / day .Fortunately we have a Frigomar Aircon 42K BTU ….at bit over specced for the boat .The thing being a AC to D.C. inverter tech with variable speed D.C. motors running the single compressor it’s got a tiny current draw . Blurb says as low a 2 A .I must stress it was specced for it silence not current draw .
If we don‘t go out its on 24/24 and if we do for a swim its back it’s on from 4 pm to 11 am next day .
Electric hob and two fridges .
One more thing not touched upon ……well briefly by hurricane changing a fridge .and reading your post your electrical guy who discovered your charger consumption.
A few yrs ago our OEM charger packed up circa 2002 so nothing unusual.
It was rated at 30 Ah for domestics of 2x180;Ah .lets just park the same size engine batts assume the just sit after a day out ready for tomorrow s trip .Need no charge worth mentioning .
The same guy a boat sparky that fitted the Aircon did his maths 2016 ish and came up with a 80 Ah all singing and dancing multistage charger .
My point is this the new 80 Ah one can stuff up the batt bank (s) quicker get its self down to its trickle / float + lowest mode faster .
If the smaller OEM 30 Ah was still alive apart from the basic fewer functions it would probably be for want of better wording “ revving it nuts off “= net result burning up more shore power to keep the batt charged than the bigger 80 Ah floating ….if you see what I mean ?
Not sure what the maths are for charger size ? I just went with his professional advice.You know the fraction of charger size / Batt capacity-
Was 30. /2x 180 or is it 30 / 4 x 180 if you inc the what should be the full engine bank ?
Now it’s 80 / 2x180 when we park up assuming the engine banks topped up on the run out ?
As far as charging PAYG in this instance for us we prefer it .Last yr ( pre Putin ) I think we went through £3-400 a year max .
Where as in La Napoule our service charge for a 14x 3.8;M berth was almost €4000 payable in advance in two instalments.
There are more folks who spend more time than us and have by todays standards inefficient kit on board .
Dividing it up ( with a size delta ) masks them and punishes the more frugal .Having had both tariffs PAYG works better for us .
A couple of the marina staff told me that, on average, there is a boat fire every fire years in MdL !!!
If that’s true, and it sounds like it probably is, then that’s a valid reason for them setting the rule. I’ve done the dock walk and spoken to a few owners about leaving their boats plugged in - the response was very mixed, but most didn’t know that leaving it connected was actually forbidden by the marina.
