Seastoke
Ok my two anodes under the stern one each side , one was half eaten away after a year And one disappeared . Why would all this happen
What’s prudent.Oh dear me. That's what anodes are designed to do when there is electrolysis. So the answer to your question is "electrolysis".
A prudent man would now look for evidence of galvanic corrosion on other parts of the boat in case the components fail and cause the boat to sink.
Someone is using your boat when you are not thereIt’s on the hard ,
Mr GogleSomeone is using your boat when you are not there
It’s time for multi meter, me thinksA year does seem quite short life for an anode to last
Perhaps the boat normally moored next door to you hasn't had its anodes checked in a long while and has been consuming your anodes.
One has been stolen.Ok my two anodes under the stern one each side , one was half eaten away after a year And one disappeared . Why would all this happen
Mr GogleOne has been stolen.
The anode bolts on the bad side had corroded off , I am going to replace all connections at the stern then check resistance , between each one , is there any thing else I can do.one being half eaten sounds normal ish - but ask other boats in the marina/area how they get on.
One disapeared completely - they can come undone! It might just have not been fitted correctly and it just fell off at some point.
Galvanised bolts , and zinc anodes, I think you are onto something as the connections on the anode were poor , so I have some multi strand 10 MM cable to renew which will be with the more robust crimps .Are you sure they aren't aluminium anodes?
This happened in another marina too. Someones saildrive fizzed away and others had a rapid depletion of their anodes.. A fair number of boats at Bangor have suffered fast anode depletion but the marina are adamant there are no issues..
