Annual Anti fouling
Edwardo
7 Aug 2001
Can anyone tell me if it is necessary to apply antifoul each year. The hull seems pretty clean but if I dont re-coat will I get problems?
Cheers
AndrewB
7 Jun 2001
Dover/Corfu
No long-term problems are caused by not antifouling, but you may of course get a lot more fouling next year.
Some people antifoul religiously every year, others leave it until the old seems to have stopped working. Its more essential for a racing than a cruising yacht. Areas/marinas differ a lot regarding the amount of fouling you pick up, and a rolling stone gathers no moss (well, less than it would otherwise).
Chris_Robb
15 Jun 2001
Haslemere/ Leros
some antifouling manufacturers say that theirs will do two seasons. Its up to you - you may find that when you are off for your august hols - your boat is covered with weed and you have to slip at vast cost - in which case you will have wished you had put a new coat on.
Personally, I always reantifoul as to slip a 40 footer mid season will cost more than the antifoul (£160.00), apart from the hasle
claymore
18 Jun 2001
In the far North
Agree entirely - if the boat is out of the water now - you may as well get it done. I antifoul and do the boot top each season and don't get barnacle growth at all - so I feel I may as well stick to current practice and keep doing it each Easter just before she goes back in.
regards
Claymore
Chris_Robb
15 Jun 2001
Haslemere/ Leros
Re: Annual Ritual
I enjoy the anuual antifouling session - its a bit of a ritual and means life is coming back into the world - I hate the winter.
No - I won't do your boat!
AndrewB
7 Jun 2001
Dover/Corfu
Not me.
I used to, but now only antifoul once every two or three years. Main problem locally is with slime. As that grows mainly within a few inches of the waterline, it can be cleared in the water, going around the yacht with a scrubbing brush occasionally. Interestingly, the grey mullet in our marina make a pretty good job of cleaning the boats of slime - but they won't touch freshly antifouled boats.
ccscott49
7 Sep 2001
I antifoul when I need to a look under the boat tells me when, i also find it cheaper to do it after the spring rush, when most yards are empty, the days are longer and weather is better aswell. I can get mine done in two days, two people getting after it, no pussy footing about, even if its raining you can scrape.
