Neeves
Phil,
Next time you go sailing and the weather is reasonable , take the chain out of the bow and leave it at 'home'. Find a crew member of about 50kg and have them stand on the bow as you sail to windward. Its a very crude experiment but they are the weight of the chain you removed. Have them move from the bow to the cockpit and see if you can tell the difference - that's what your chain is doing to your sailing performance - and this difference will be much more pronounced on a small yacht. It could be you don't mind in which case do not worry and go off and enjoy yourself.
The experiment is ideally conducted with a bit of chop. I'd not do it in inclement weather - the crew member on the bow may not enjoy being the lab rat and maybe don't tell them they are a replacement for some manky chain!
If Jimmy Green are suggesting 10mm is suitable for a 3t yacht I shudder to think what they are suggesting for a 12t yacht. I also doubt their reasoning and the recommendation casts doubt on their knowledge.
6mm would be more than adequate.
Jonathan
Jonathan
