Neeves
The pictures are dated June 2015, so the water would not be that cold, the chart is way north in Scotland.
So 5C not unreasonable then!The pictures are dated June 2015, so the water would not be that cold, the chart is way north in Scotland.
Lochinver basking in the Gulf Stream.So 5C not unreasonable then!![]()
I am serious about the use of rated shackles
This image was supplied by a member here. Not a rated shackle, failed on retrieval of a Rocna anchor. Apart from not being rated its the wrong shackle anyway. Use a bow (sometimes called an anchor) shackle
I have tested to destruction using NATA approved test facilities many 10s of rated 3/8th" shackles either G60 or G80. Some did not meet the suppliers specification - until I tested (and then they changed the specification to meet my results). Without exception all the shackles failed with the shackle pin shearing at the pin. Crosby, Yoke, Peerless and Campbell all met the manufacturers specification. I have not tested Van Beest shackles, difficult to source in Australia. I have tested other shackles - but if you want a degree of certainty choose from my list - some are easy enough to source in the UK, including Crosby and Yoke. I have bought Crosby shackles fromTecni, I think based in Bristol.
I think you will find a number of people recommend the use of rated shackles from reputable manufacturers. Wiring a shackle bought from a hardware store will not, ever, make it stronger. I have never heard of anyone actually breaking a shackle by twisting, by hand or even helped by shifter. A rated G80 3/8th shackle takes 10t to break it - yet you did it easily.
You cannot be serious.
By all means mouse a shackle pin, its an excellent idea - but for anchors mouse only reputable shackles - not ones you can break by hand, or using hand tools.
If you know of a source of reputable shackles subject to independent testing please post so that the members can enjoy the information.
Jonathan
I don’t understand…they lost the anchor…but retrieved the tiny bits of the broken shackle off the sea floor ?I don't have the pieces - only the picture and the sorry tale of the lost Rocna anchor.
Never guess but the I might assume a G30 chain. The shackle is unrated, no Grade - just one of those shackles, maybe, you can buy in your local hardware store (to secure your dog)
The owner said the shackle failed when it hit the bow roller - so I assume (again never guess) that the actual failure occurred prior and the hitting of the bow roller was the final straw that broke the .....Interestingly the shackle shows little distortion.
I was interested that the owner lost his anchor but saved the pieces. I don't question the veracity of members willing to send me pictures - I think them both honest and generous and I am grateful.
No - on the stainless part of the bow roller assembly.I don’t understand…they lost the anchor…but retrieved the tiny bits of the broken shackle off the sea floor ?
Jonathan
What did they ram ?If you check the pictures the 3 pieces of the shackle were attached to the chain. I don't know but if the shackle eventually failed when the fluke rammed the bow roller then the loose part of the shackle would be sitting 'in' 'on' the bow roller - as the unsecured Rocna waved goodbye as it returned to the sea.
Not impossible.
As an owner - if this happened you would be so surprised you would simply have insufficient time to catch the disappearing anchor.
And as all the pieces were photographed this must be near enough what happened.
Jonathan
I have been guiltyWhat did they ram ?
It’s quite possible that the breaking shackle and the loss of an anchor saved the boat from structural damage if the force wasn’t absorbed by the shackle
I see no evidence of a progressive fracture or bright final fracture. Not knowing when the rusting took place does not help of course but we do know that the shackle held the boat at anchor prior to its demise on recovery.
There is no doubt that some of the anchoring kit sold in chandleries is very dodgy. One of the C-links I tested was very poor indeed, the fracture face looked nothing like steel.
When I worked at Thornton there was a week when I had five Stanlow pump shafts on my desk. Every one had failed as you describe, due to non-existent radius between shaft and flange.I know its a different item ... but your comment about fractures reminds me.
I had a Capri 2.8i Special .... and was driving from Portsmouth to Brighton. On the the old Shoreham road just past airport - was a roundabout ... I'd been happily bowling along the road .. slowed to the roundabout started to go round it ... all hell broke loose ... car span - hit the kerb and slid luckily not hitting anything else.
Car behind stopped to see if I was OK ....
I got out of car and rear wheel offside wheel was folded under the car holding it up. Car had basically slid on it. Front suspension strut pushed back of course.
RAC called ... recovery vehicle arrived ... guy took one look and said :
Another one ! the Granada 2.8 with same - seen that do it as well ...
Car was hoisted up and trucked back to dealer .. it was 2 days short of the first year on warranty ... RAC guy and I agreed that we needed to make sure Ford dealer didn't pull a fast one .. so we put the car across their workshop doors. I made night watchman make entry in his log car had been delivered at xx:xx time etc.
The Dealer accepted fault and gave us the reason 'unofficially' ... Sales Manager was a friend ...
Ford had a batch of drive shafts fail .. and mine when investigated was in that batch. Basically the ahsft had sheered right at the joint to brake back plate ... wheel folded under. He admitted to me that you could see the fault in the shaft ends.
They commenced repairs under warranty ... but halfway through the Regional Ford Rep got involved and stopped all work - denying all responsibility.
I called in independent Assessor who wrote what he was told ! I know for a fact because I was told again by my guy .. that Assessor basically looked at the car in pieces .. spoke to Ford Rep and mechanic ... wrote report.
I had already informed Insurance ... who quite rightly said its a Ford Warranty issue.
Ford - when I argued - stated they wanted to take the car away and conduct tests on it at Thornton Centre ... time frame likely 3 months.
I wrote recorded signed for delivery letter to Ford Boss ...
Outcome ? Big Brother. Insurance company repaired it in the end ... I sold it and bought the better performing earlier non LSD version .......
The story is to illustrate that there is no g'tee even with brand name.
A school pal of mine owns a company XXXXX Screws Ltd in UK (name withheld) ... they deal in all sorts of metal fastenings etc. They have clients that require a Certificate of Test before items can be used in sensitive work - such as aero / space etc. Steve has told me that 99.9% of the time all is good .. but there have been failures of one or two despite the batch testing of shipment.
