Roberto
Hello,
I have two alternators with belts of very different lengths. When I need to tension them I use a wooden hammer handle to move the alternator body and then tighten the locking bolt, the result is often far from perfect in particular for the shorter belt whose alternator sometimes outputs >70A.
I have seen some people have fitted a turnbuckle between the two bracket bolts, on other solutions seen on the web the turnbuckle is inserted between the two pulleys; on my alternators those methods cannot be used.
I would like some sort of variable length rod or device to be inserted inside the slots of the brackets (two red lines), then for example by screwing/unscrewing a nut increase its length as to move the alternator bolt until the proper tension is found, lock it in place, then unscrew the device and remove it. Does such device exist? Searching the internet gives links to additional belt tensioning devices which are to be fitted permanently, additional pulleys etc, and I have no place to install them.
Or could this sort of inflatable cushion be of any use?
