Carmel2
Has anyone tried using one with an android tablet? Did it work?....
Thanks for this, I will give it a go!
@carmel2 - Have you bought the Alpha WIFI booster? I don't know how techy minded you are, but if you've not already bought the alpha WIFI booster may I suggest an alternative solution?
The Ubiquity Bullet, with a high gain antenna, plug all that into TP-Link MR3020 router and you will have a setup that gives you WIFI from over 1km away and all for about £120. Let me know if you want more info and I'll forward on some details about our setup.
It's not that hard to set up even if you're not an IT expert, its just it's not just a plug it in and use it solution.
Either way good luck what ever solution you go for.
Actually I would be interested in a "non geek" simple explanation of this myself although I will be using a PC with windows 10 and/or an apple tablet..... Please keep it simple though for the sake of a 73 year old fart .........
It is the AWUS036H, I already have it and used to use it on a old bit of kit.
I assume you mean explain the Ubiquity bullet part. Actually very similar to Alfa kit being discussed....
...2) The wired connection between the booster and the router is different. Alfa uses a USB cable and Ubiquity uses a "network" type cable. The latter is better for longer cable runs and also for supplying power to the booster.
Thanks Robbie, looks like Alfa are doing the whole kit in one box now http://www.amazon.co.uk/gp/product/B019VLO8CE?keywords=Alfa wifi&qid=1457703002&ref_=sr_ph&sr=1
I just bought the Alfa AWUSO36H luxury kit on Amazon that includes a 9db ariel. Then added an active 4 meter extension. Works well enough on my old laptop and am going to buy the R36 next to give me wireless connectivity with my android tablet and phone.
The laptop was important as the software came on a disc and needed several attempts to install properly.
How it would work without a laptop for the setup is worth considering if one is unavailable.
Does the R36 confer any advantage over running Vitual Router on a Win7 laptop with an AWUS036H to create a wifi hotspot?
OK, thanks. I was under the impression you needed Enterprise or Ultimate to create a WiFi hotspot without VR. I have 7 pro which doesn't show the sharing option menus described in online tutorials for windows hotspots.
Another thing...is it not more cost effective, and simpler to setup, a cheap netbook in lieu of the R36, with the added advantage of an additional stand alone device on board (handy for Memory Map charts and marina LAN access)? I'm using a 10"Asus which cost £30 on ebay.
